Rubber boots & Turn Signals - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda PowersportsNew Bonneville
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 06-22-2008, 01:17 PM   #1 (permalink)
Question Rubber boots & Turn Signals
I'm a moronic and pathetic individual when it comes to any mechanics on my bike. (to provide vivid detail, I was elated by my ability to install a new horn in under 2 hours)
I purchased my 2001 955i nearly a year ago, and its my only means of transport. Being a new father of two, I was dumbfounded when my wife permitted me to sell my car for a Tiger. (then I looked at the new life insurance and understood).
Unfortunately, the previous owner kept my bike in a half-shelter, so there was some exposure to the elements. A majority of the rubber is dry-rotted, including the boots around the mirror connectors. Any ideas where to find replacements? Other rubber bits I might want to check out as well?
ALSO...Recently, some fat Harley puke broke off my turn signal. Being a cheap meiser, I'm hoping to find the best bang for the buck. Should I go with LEDs and if so, is there a minimally technical means of doing so? Any recommendations are welcome.
Superhauck is offline
Old 06-22-2008, 01:31 PM   #2 (permalink)
Favourite Bike: Bette 99 Tiger
The rubber boots are part and parcel of the mirror assembly, the best I could come up with was to cut down some industrial cable gland shrouds.
PeteH is offline
Old 06-22-2008, 06:23 PM   #3 (permalink)
Favourite Bike: Tiger 955i '06
BoneyMalloney's Avatar
The rubber boot covering the brake light switch rotted away within months of buying a brand new 2006 Tiger, then the strap holding the battery in place rotted away... Get the picture - yours are probably long gone! Not worth replacing with the same crap - use something else.
LED's are an expensive gimmick - get down your local breakers yard or take one off a Harley...
Chris.
BoneyMalloney is offline
Old 06-22-2008, 11:38 PM   #4 (permalink)
Favourite Bike: 2005 Triumph Tiger 955i
The Kurgan's Avatar
My rear brake light switch was rotted with 1400 km on the odometer on my 2005 Tiger.
I just cut it off... filled in the black 'plug' with silicone and wrapped the whole thing in quality heat and UV resistant black electrical tape. No problems.
2005 Triumph Tiger 955i British Racing Green
Photos of my Tiger: CLICK HERE
Have a listen: CLICK HERE
R.A.T.# 1081696
The Kurgan is offline
Old 07-13-2008, 07:25 PM   #5 (permalink)
Option for dry rotted rubber
I found this product at the hardware store called "Dip It' and it basically puts a weather-proof rubber coating over anything you dip into it. Most people put it onto older wrenches and the like to improve grip. Just thought I'd add that, as it created a near perfect replica of the original boot for the mirrors.
I'm now trying to dip dry rotted pieces into it to see if it "rejuvenates" them or at least makes them more servicable.
Old 07-25-2008, 01:32 PM   #6 (permalink)
Triumph 'the thieving ****ers'
I was just about to post almost the exact same question, after a trip to Metropolis Triumph dealer, £39 each for a mirror with the rubber, you cant buy them seperatly !, the rubber boot for the clutch pedal was £5, thats probably 15p's worth of rubber !
My mirrors are getting a bit rusty on the stems and I thought a rub down and spray over with plasticote or something, but the rubbers are shot to pieces, which would have ruined my efforts !
But I love Superhaucks idea of using liquid rubber, i'm off to see if I can track some down, anybody know if the main UK DIY shops sell such stuff ?
All the gear and no idea !
snaphappyuk is offline
Old 07-25-2008, 03:42 PM   #7 (permalink)
I have just serviced my rear brake caliper and needed a new dust seal for the sliding bracket, I had to fit a Honda one as Triumph dont list them.
Most of these perishable items are used across the Triumph range and you would expect to be able to get hold of them, what if everyone emailed Triumph and complained then compare the replies.
PeteH is offline
Old 07-26-2008, 08:45 AM   #8 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
I'm sure I've seen the mirror boots regularly on ebay.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 07-27-2008, 07:09 AM   #9 (permalink)
I do like PeteH's idea of all complaining to Triumph, I'm going to email 'em right now, I'll let you know what reply I get.
I'll also keep an eye on ebay, never seen them on there but worth a look.
Cheers guys.
Old 08-19-2008, 12:58 PM   #10 (permalink)
I emailed Triumph on the 27/7 and am still waiting for a reply So, as im doing the factory tour tomorrow, I`ll ask the question there.
PeteH is offline
Source for Champion Spark Plug Rubber Boots triumphgeezer Classic, Vintage & Veteran 5 11-08-2010 08:35 PM
Rubber boots TonyD Hinckley Classic Triples 20 03-08-2007 02:08 AM
turn signals hardboild Triumph SuperSports 1 09-26-2006 08:43 AM
Replacing the intake rubber boots Hinckley Classic Triples 5 08-03-2004 11:42 AM
Cracked Rubber Boots Maintenance & Workshop Talk 4 09-30-2002 03:32 AM
