Tiger Question - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 06-06-2008, 05:14 PM   #1 (permalink)
Tiger Question
Hi,
Another newbie question.
I have bought some LED's to replace the dash lamps on my 955i, but can't see how to access the bulbs to change them. I've removed the two screws on the dash panel but nothing moves.
Can someone give me a step by step guide on how to change them?
Thanks in advance
Swooper is offline
Old 06-06-2008, 05:32 PM   #2 (permalink)
Favourite Bike: 2003 Tiger 955i
Other Motorcycle: '99 Striple 955i
Extra Motorcycle: '72 BSA B25FS,'53 AJS 18S
Ah, when I was a newbie (just three months ago), I thought those two screws would do the trick too. However, the handbook instruction to "remove the cockpit" really means "remove the cockpit fairing".
ChazzyB is offline
Old 06-07-2008, 05:49 PM   #3 (permalink)
Favourite Bike: Norton Commando
Tiger_50's Avatar
Hi, I did mine about a month ago and the whole front fairing has to come off. You might need torx as well as allen keys as the screws are a mixture, at least mine were.
Going from memory the job goes like this.
Start by removing the 2 black plastic pieces between the fairing and tank. (they hold the front indicators)
then remove the screen (4 x plastic screws)
then remove all the screws holding the fairing, careful not to loose any of the rubber bushings. (4, I think 2 in front and 2 more at the sides)
the fairing should now be removable.
if your just doing the dash bulbs then you now have full access to the bulb holders.
Remember the LED's only work 1 way so test after putting them in.
If it doesn't lite up then take it out and turn it 180 degrees then put it back in.
Make sure everything is working fine before you start reassembly.
If your doing the clocks as well then you will probably have to remove the head lights to get in to all the clocks, I know I did.
Just take your time and you'll get there, it took me about an hour to do the job.
Hope this helps and I hope I haven't forgotten anything important.
It's well worth doing, I noticed a big difference.
Cheers Paul.
Tiger_50 is offline
Old 06-07-2008, 08:45 PM   #4 (permalink)
Tiger 50
Many thanks m8.
That's my job for tomorrow
Swooper is offline
Old 06-10-2008, 08:39 PM   #5 (permalink)
Favourite Bike: 2002 Tiger 955i
cjmadura's Avatar
Other Motorcycle: 2008 KLR 650
Question Led's ??
This sounds interesting!
What type of bulbs are fitted originally?
If not LED's, What type of LED do I need to buy (I haven't a clue about these!), and do they fit directly into the bulb holders? The original bulbs wash out easily in the sun (granted, there's not too much of that here in Portland), and I'm tired of cancelling my indicators 3 miles after my turn.
Thanks for any info!!
cjmadura is offline
Old 06-11-2008, 12:35 PM   #6 (permalink)
Tiger_50's Avatar
Exclamation Bulb's to LED's
Hi, the leds plug in to the bulb holders providing that you buy the correct size.The Tiger dash uses 286's I think and the clock's use 501's so you will need 2 green 2 orange 1 blue 1 red for the dash.
There is more info on this forum somewhere (do a search for it) as I'm not 100% sure of the sizes and I don't want you to buy the wrong sizes. On this side of the Atlantic we buy from http://www.ultraleds.co.uk
I think KuzzinKenny started this bulb changing thingy so do a search for his posts and you will get more info.
Hope this helps.
Cheers Paul.
Tiger_50 is offline
Tiger 955 question Swooper Tiger Chat 13 06-05-2008 08:57 AM
07 Tiger Seat Question Chyron Tiger Chat 4 02-27-2007 08:00 PM
Used Tiger question TT600Nut Tiger Chat 3 11-26-2005 06:41 PM
'71 Tiger electrical question antstuie Classic, Vintage & Veteran 0 08-30-2005 09:28 AM
One more Tiger Question. Bushwhacker Tiger Chat 11 08-05-2004 03:31 PM
