I haven't seen this screen, yet; however, I doubt if it is as tall as the CALSCI screens. Log onto tiger1050.com and do a search on screens. You will probably find something on every screen available. I believe I read some negative comments on the Thunderbike Touring screen.
Go to calsci.com and look at their screens. I have the Calsci+7 and it works very good for me...I'm 5'8" with a 29" inseam. They make a +9 and a +10.5, also. These numbers are the number of inches taller the screen is over the stock screen.
Because of the distance the screen is from the rider, no one screen will work for a majority of riders--too many variables, IMHO. Since the screens are expensive, I would phone the vendor and see if you can return the screen if it does not work for you...I believe some will work with you on this. I think someone on the tiger1050 forum said Calsci would do this.
Good luck,
Larry
