Direct wiring a Garmin 2610 - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 05-17-2008, 07:44 AM   #1 (permalink)
RT
Favourite Bike: 06 Tiger Caspian Blue
RT's Avatar
Other Motorcycle: 07 America Black & Chrome
Ok lets try this again. Just stuck this on as as reply to a Vario question. It's early.
If I want to wire a 2610 direct to battery what else do I need beside the harness from Garmin???
"Who is John Galt?"
RT is offline
Old 05-17-2008, 02:22 PM   #2 (permalink)
Favourite Bike: Tiger 05
Silverstripes's Avatar
A fuse in the line and perhaps a switch to isolate
Silverstripes is offline
Old 05-17-2008, 03:46 PM   #3 (permalink)
Favourite Bike: My 06 Tiger
Outrunner's Avatar
I have mine wired direct to the battery including the fuse that came in the harness.
Andy.
Every day above ground is a good day!
Outrunner is offline
Old 05-17-2008, 07:07 PM   #4 (permalink)
Lightbulb Garmin wiring
Hi
I have just wired my Zumo 550 in behind the fairing, I found a positive and negative on a large block connector that is live with the ignition on and dead when turned off, it was pushing about 14v when the engine was running, the garmin shuts itself down after 30 seconds when the ignition is switched off unless you select to change over to the internal battery.
I found it easier than trying to route the harness under the tank and around the headstock.
If it's not green, it ain't mean!
Jacko34 is offline
Old 06-05-2008, 07:45 PM   #5 (permalink)
Favourite Bike: 2001 Adventurer
Other Motorcycle: 2006 tiger
garmin wiring
Would someone please post some pics to help us rookies out please. I just got my zumo 550 and need some help.
scguy is offline
Old 06-09-2008, 05:42 PM   #6 (permalink)
FantomasRR3's Avatar
As simple as 123
I just connected my Zumo directly on the battery. It works as a charm ! I leave it max 3 days on the cradle and my battery still has full power when starting again. Why bother connecting it to the ignition or install a switch.
Tiger 1050 '08 White
160km commuting every day/weather
Fog additional lights
Oxford muffs
Givi 46 topcase
Triumph sport exhaust
TG Warning System
FantomasRR3 is offline
Old 06-09-2008, 06:07 PM   #7 (permalink)
Yes, my Zumo has been wired directly to the battery for the last 12 months. No problems at all.
Pickaxe is offline
Old 07-04-2008, 11:32 AM   #8 (permalink)
Favourite Bike: All of them
NinjaRAT's Avatar
Other Motorcycle: '06 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
I'll risk dragging this oldish thread back from the dead to ask:
When wiriing directly to the battery, is it a good idea to use some sort of connector, or simply take the bare wires and wrap them around the battery screws?
I had it in my head to maybe see if Powerlet made some sort of adapter that I could connect the wires to and plug in to the accessory outlet, But I didn't see anything on their site that looked applicable. Then again, I'd have to compete with my heated gear in the winter.
Oh, and I'm referring to a Zumo 550 my wife just got me for my Birthday.
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
NinjaRAT is offline
Old 07-04-2008, 05:19 PM   #9 (permalink)
Favourite Bike: Tiger 955i '06
BoneyMalloney's Avatar
I thought the wires were a bit too thin (Garmin Quest) for routing and attaching to the battery, so i simply 'piggy backed' them on the wires for the heated grip switch. Just find the live feed, ie. switch on your ignition and find the connector on the back of the switch that is live when the switch is in the off position. You can use one of these (the right size) to connect to the back of the switch.
No problems two years down the road...
Hope that helps, but if you do decide to connect directly to the battery make sure it is a very good connection and no bare wires! If they touch the frame - Ouch...
Chris.
BoneyMalloney is offline
Old 07-10-2008, 09:41 AM   #10 (permalink)
RT
RT's Avatar
ended up fishing the wire under the tank before attaching with wire ties than routing up to battery. Used fork connector on bare wire end before attaching to battery. So far so good.
"Who is John Galt?"
RT is offline
Garmin 2610 GPS RT Tiger Mods & Bolt-Ons (archive) 10 12-09-2007 09:25 AM
Garmin 2610 Questions Pilsbury Sprint Forum 4 08-14-2006 11:41 PM
garmin 2610 coleng Sprint Forum 4 11-13-2005 12:54 AM
Garmin 2610 Shaman Sprint Forum 3 03-04-2005 10:12 PM
Anyone have a Garmin 2610 Hawk1340 Sprint Forum 6 01-04-2005 10:11 AM
