Help! main fuse, where is it?? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleOntario TourismSportbikeTrackGear
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 04-23-2008, 04:47 AM   #1 (permalink)
Newbie
I have a Tiger 955i 2005 model and think i've blown the main fuse while attempting to reconnect the horn wire as ALL electrics have now failed and all other fuses in the fuse box are ok!!
But looking at the Haynes manual I'm still unsure where the main fuse is located on the bike, even with the side panels off I can't see it.
Can anyone please point me in the right direction?
Cheers
Tom
Tigsmate is offline
Old 04-23-2008, 08:56 AM   #2 (permalink)
mca156's Avatar
Have you looked down the left hand side (as your sitting on the bike)of the battery box, cliped into a holder, there`s one threre.
mca156 is offline
Old 04-23-2008, 11:45 AM   #3 (permalink)
Favourite Bike: the tiger at the mo
bearusa's Avatar
Other Motorcycle: xr 400 used offroad
you actually need to remove seats and side panels left, to reach the main fuse without strecthing the wires it actuallt clips to the side of the battery case,, good luck just remember to check all wiring before to make sure you have connected them and not leaft any live exposed,, it sounds strange that the main fuse has blown and not the individual circuit you were working on,, post results when possible
taming the tiger?
bearusa is offline
Old 04-23-2008, 11:48 AM   #4 (permalink)
bearusa's Avatar
ps when working on any electrical circuit it is strongly advised to disconnect the battery first, you can actually short the whole system out including
the ecu which controls everything to do with ignition etc,, if this blows you will not get any sort of circuit (no dash lights etc) and the bike defo wont start then,, good luck
taming the tiger?
bearusa is offline
Old 04-23-2008, 12:02 PM   #5 (permalink)
bearusa's Avatar
the fuse is hear just infront of my finger on the side of the battery case,,
hope this helps?
taming the tiger?
bearusa is offline
main fuse blowing (06 Sprint ST ABS) Lumpy Maintenance & Workshop Talk 7 04-30-2007 12:18 PM
main fuse highcard Hinckley Classic Triples 2 08-12-2006 11:47 AM
Main fuse.... HELP!!!!!!!!!! Backlash Daytona Deliberations 0 08-04-2006 12:20 AM
Fuse ID on '04 RS?? jellero Sprint Forum 1 07-27-2005 03:25 AM
Please Help!!!! Cooling fan, Main fuse issue, Electrical issues Maintenance & Workshop Talk 10 07-28-2004 10:33 AM
