Headlights adjustments - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsSportbikeTrackGearMotorcycle.com
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 04-14-2008, 07:30 AM   #1 (permalink)
Favourite Bike: My Tiger - 05 Silver
Red face Headlights adjustments
Hi all - rookie Tiger-05 owner as well as Rat.Net member posting for advice:
My Lo Beam head light is way too low and needs to be adjusted. Referred to my owner's manual and the info I got to adjust the alignment was: "Remove Cockpit". Can anyone give me a clue on what and how to dismantle the Tiger's head?
BR
Mats
Bandito is offline
Old 04-14-2008, 10:00 AM   #2 (permalink)
Favourite Bike: 2003 Tiger 955i
Other Motorcycle: '99 Striple 955i
Extra Motorcycle: '72 BSA B25FS,'53 AJS 18S
Yes, this foxed me when I bought my '03 Tiger recently. By cockpit, read fairing. You'll need to remove the screen first to get at the two screws underneath. I'm about to do mine to a) adjust the headlights (too high) and b) remove the tank to fit a Scottoiler.
ChazzyB is offline
Old 04-14-2008, 02:34 PM   #3 (permalink)
Favourite Bike: Hayabusa pre-restricted
Nigeh's Avatar
Other Motorcycle: Honda CR500
Hi Bandito
Sorry this is of no use to you in helping with taking fairing off but I could not help notice where you are based, don't suppose you know the Ghost rider???????
Nigeh is offline
Old 04-14-2008, 07:51 PM   #4 (permalink)
Favourite Bike: 2006 Triumph Tiger Black
Other Motorcycle: 2004 Speedmaster
Fairing Removal
To remove the Tiger fairing:
Remove the 4 screws on your windscreen. This will expose two screws underneath that hold the upper fairing on.
Remove the turn signals, one screw inside by the forks and the two visible ones outside. Just pull the wire connectors, they pull apart without pushing any tabs etc...
Remove the two screws behind the windscreen, and two at the lower back of the fairing. Pull forward to pull the headlight gaskets off the lenses.
To adjust the lights: The vertical adjustment screws are the two at the top between the lights. Turn clockwise (as viewed from the back) to lower the beam, CCW to raise. You can decide what's right for you, but the spec is a 4" drop at 25' to the top of the beam.
Be careful putting the fairing back on, it is really easy to break the plastic elbow on the coolant overflow tank, make sure the hose is routed correctly before pushing the fairing back on.
Digger is offline
Old 04-16-2008, 12:28 PM   #5 (permalink)
blacktiger's Avatar
Actually to adjust the height of the aim you don't need to remove anything. There's a small thumb wheel just reachable by squeezing your hand up under the front of the fairing. It's fiddly but can just be done with finger tips.
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
blacktiger is offline
Old 04-16-2008, 08:27 PM   #6 (permalink)
The thumbwheels are for left and right adjustment. The up and down are unfortunately hex and need a socket.
Digger is offline
Old 06-01-2008, 07:52 AM   #7 (permalink)
Thanks for tips - Headlight adjustments
Thanks a lot for your postings - sorry 'bout my late reply. Specially to Digger, good and detailed info appreciated! Will try immediately.
To Nigeh: Even if one of the most spectacular Ghost rides is the same route as my way home from work (Stockholm to Uppsala) he is not a personal friend
BR
Mats
Bandito is offline
Old 06-24-2008, 01:57 PM   #8 (permalink)
I read this in the manual.
After trying it it is backwards! The top screw adjust left to right and the bottom thumwheel adjusts height.
At least on my tiger. I can now see much better at night.
sanjoh is offline
Old 07-13-2008, 07:20 PM   #9 (permalink)
Headlight Bulb replacement
Digger rules, thanks for the step-by-step on this. I'm definitely special-ed when it comes to anything mechanical, but I used your directions to replace my bulbs with brighter ones (same voltage/watts). Much appreciated
Hauck
'01 Black Tiger
Superhauck is offline
Old 07-21-2008, 08:04 PM   #10 (permalink)
Favourite Bike: '06 Tiger
I significantly improved my headlights by replacing bulbs with Philips Blue Vision.
Improves lighting, but biggest gain is that with the blue hue you are far more visible to oncoming traffic.
stanegoli is offline
clutch adjustments retrobiker Classic, Vintage & Veteran 10 11-21-2007 09:24 PM
TWO-UP ADJUSTMENTS TIGERBLOG Tiger Chat 1 06-18-2007 03:14 PM
valve adjustments LUCAS Twins Technical Talk 26 09-21-2006 07:33 PM
Valve Adjustments vol245 Twins Talk 6 05-04-2006 09:20 PM
Headlights adjustments Leebo Sprint Forum 6 08-31-2004 07:39 PM
