Kappa Adaptor Plate - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 03-20-2008, 02:05 PM   #1 (permalink)
Favourite Bike: Sprint ST 1999
Other Motorcycle: XR400 2003
Kappa Adaptor Plate
I have a 2006 955 Tiger. I bought a Kappa adaptor plate to fit a top box. I am having trouble fitting the plate properly. The metal fasters are shaped for a round tube. The existing rack is squared on the bottom. Hence it does not fit well.
Has anyone else had this problem?
Also has anyone fitted a span adjustable clutch lever?
kiwijohn is offline
Old 03-22-2008, 05:30 PM   #2 (permalink)
KTC
I have a Kappa top box fitted to my '04 Tiger. The 'box came with my previous bike so I don't know how new it is. Have a look at the attached photo to see how I fitted the plate. It is very secure (well it hasn't come off so far....)
KTC is offline
Old 03-23-2008, 12:56 PM   #3 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
Those look like the standard fittings, although the bolts they supply aren't quite long enough. Mine's been on for 3 years without any problems.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 03-23-2008, 01:59 PM   #4 (permalink)
Thanks for the photo. This helps alot.
kiwijohn is offline
Old 03-27-2008, 08:16 PM   #5 (permalink)
I think the Kappa plate and Givi plate are same (seemingly father and daughter business venture in Italy) and the photo looks more or less how my Givi plate is fitted.
Somewhere in the forum this has come up before and they can be found. I seem to recall they were expensive.
We all have the same problem i.e. the span is big.
The trick is to slacken of the adjuster and use thin gloves.
Chris
Arrybash is offline
Old 03-28-2008, 08:26 PM   #6 (permalink)
Favourite Bike: 06 Tiger
Yes, same experience as Arrybash and iansody have had. The plate for mya 45L Givi is exactly the same and yes, the supplied bolts are too short but easly replaced with longer ones. I checked it regularily after first installed but it never loosened up. Of course a more elegant install would be through holes drilled in the rack, but could not bring myself to do this.
TJoe is offline
Mirror to Bar adaptor PeteH Tiger Chat 0 01-25-2008 09:56 PM
Mirror Stalks or adaptor? Anne Twins Technical Talk 7 10-10-2006 08:13 AM
Kappa Hard Bags & Turntable Pictures now available triumphantguy Hinckley Classic Triples 10 05-07-2005 11:06 PM
Kappa Luggage for TBird Tbird900 Hinckley Classic Triples 11 02-13-2005 12:26 PM
Givi/Kappa Luggage BigStripey Tiger Mods & Bolt-Ons (archive) 5 02-04-2005 08:15 PM
