when you pull the front seat off you will seel the adjustment points. most seats are set to the lowest point. you can try using setting one in front and two in the rear but i would keep it the same for both as you might be stressing the plastic too much by not keeping even pressure on all four points.
Joe
06 Speedmaser
07 KLR650
