modding stock muffler - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew Bonneville
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 02-23-2008, 09:28 PM   #1 (permalink)
Newbie
I bought my '06 in September, and it's stock as far as I know...but when I was checking out the muffler I notice that the end cap has three allen bolts holding it on. Is this the stock muffler? It has a paragraph of info and the Triumph name on it, and looks stock to my untrained eye, but I wouldn't expect a standard can to be so easily opened. I would have opened it already to see what's inside, but one of the allen heads is a little stripped and I need to find something to fit it better before I make it worse.
So, if it is the stock can, I'd really like to hear about anyone's results with modding the guts. My search hasn't turned up much. I'm thinking about popping some holes in the baffles as suggested, but I'd like to know how that's turned out long term for you guys that have tried it, and if anyone's gone any further down that road.
Thanks,
Ian
mojopwr is offline
Old 02-24-2008, 05:53 AM   #2 (permalink)
Favourite Bike: Triumph Tiger
MAX21's Avatar
Hi the 3 bolts just hold the cover on a standard can if you take this off the inner is welded in place i had the same thought with mine. In the end i found a pipe from MTC exhausts which has all the numbers but you can remove all the gubbins so it sounds sweet and its a lot lighter than standard also because it has the numbers no mot problems
MAX21 is offline
Old 02-29-2008, 10:17 AM   #3 (permalink)
Favourite Bike: Triumph Tiger 1050
Other Motorcycle: Harley Road King Custom
Extra Motorcycle: Unity Bobber being built
Max, are you saying you gutted the stock can and had a new inner pipe welded in place?
If so, did you not end up with an odd resonance fromt he inside of the stock can?
Chappy
Biker Chaplain
www.bikerchaplain.com
Harleytoo is offline
Old 02-29-2008, 12:26 PM   #4 (permalink)
MAX21's Avatar
No harley i considered pulling it apart but it ended up easier to buy a straight through can with the numbers on it
MAX21 is offline
Old 02-29-2008, 04:32 PM   #5 (permalink)
blacktiger's Avatar
By numbers, he means the Conformation Unified Noise Tested (perhaps I shouldn't put the abreviation) numbers. Our bikes have to be as quiet as a mouse.
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
blacktiger is offline
Old 03-02-2008, 12:25 AM   #6 (permalink)
They would hate my Harley! Gotta love Texas! Bigger, Badder, Louder! All Good.
Chappy
Biker Chaplain
Modding stock turn signals DIY Pics!!! D9 Twins Technical Talk 70 08-14-2011 09:08 AM
Stock muffler modification tommyturbo2 Twins Technical Talk 4 08-31-2006 04:35 PM
Use for stock muffler end caps busajack The Rocket Science Forum 7 11-16-2005 10:34 PM
2 new TORS instead of 1 new Stock Muffler d2mini Twins Talk 10 10-29-2005 08:55 PM
