LED Indicators - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 02-22-2008, 06:22 PM   #1 (permalink)
Favourite Bike: Tiger 05
Silverstripes's Avatar
Red face LED Indicators
Yep gone and converted to LED's.
I did not change the outer shells. I removed the plastic chrome reflector and made a plastic backplate the same shape.
I then drilled 5mm hole to the patern of my choice. On the front I have 25 Yellow LED's and the Rear with 20 Yellow and 5 Red, in a line in the center. The 5 Red's are wired to the Brake lights so you get the standard brakelight plus both indicators red.
The LED's were 6000 MCD and cost 7 GDP (good old flea bay). I had to replace the flasher with an electronic one again 8 GDP.
Result is that with the standard lens replaced the Red is just right and the yellow more of a spead, easier to see and much brighter than standard.
Next project is the stop and tail conversion, again to LED's
Just cant leave it standard !!!!
Silverstripes is offline
Old 02-23-2008, 05:20 AM   #2 (permalink)
Favourite Bike: tiger 955 05 silver
snakebasket's Avatar
Other Motorcycle: Laverda sf
Extra Motorcycle: Triton
Hi, sounds great, any pictures and a chance of links to the ebay suppliers?
snakebasket is offline
Old 02-23-2008, 05:51 AM   #3 (permalink)
Talking
Yes I will get some pictures up at some stage.
Also when I do the tail light I will do a stage by stage photo run.
Bottom line it depends on how many LED's you want to install and then I worked out an even patern.
I did put the LED's in clusters of 5 with a 27 OHm restitor rather than individual resistors. this cuts down on the space needed and if ther is a failure it would only be one group of 5.\
As I said pics to follow.
Old 03-02-2008, 12:58 PM   #4 (permalink)
Talking
For pictures of the LED indicator conversion clicky here. http://silver-stripes.blogspot.com/
Have a go.
Any questions PM me.
Old 03-06-2008, 03:11 PM   #5 (permalink)
Favourite Bike: Sprint ST
Nice!
Nice job on the indicators. Looks like that was was a fun little project.
Did you consider having the LED's work as running lights?
Cheers!
Mike
PS...keep up the good work.
Future Ride...(on the fence)
05+ Sprint ST ABS || 07+ Tiger ABS
__________________________________________________ _______
Past Rides...
'03 Suzuki SV1000N = RIP, '98 Yamaha TRX850, '75 Yamaha RD350
okimic is offline
Old 03-07-2008, 04:45 AM   #6 (permalink)
Yes I did consider running a row of whites on the front as I did Reds on the back (For Brake warning). This row of whites in both sides would be running lights. However I chose not to do this as the lens are standard and there was a risk of the running light showing orange. his may confuse a car driver waiting to pull out if they could only see one indicator.
I chose therefore not to do this and stay with 25 nice and bright yellows in the front.
I do have the twin headlight conversion and I also have a set of auxiliary lights running with the headlights when on main beam or the overtake flash switch. I will put this mod on my site next.
LED indicators - Help! Navy Boy Daytona Deliberations 12 03-25-2008 10:58 PM
LED Indicators blackfly Hinckley Classic Triples 4 06-13-2007 03:31 PM
LED Indicators Silverstripes Tiger Mods & Bolt-Ons (archive) 0 04-01-2007 02:05 PM
LED Indicators robnobrakes Speed Triple Forum 7 09-20-2005 12:24 AM
LED indicators Maintenance & Workshop Talk 11 12-07-2004 10:20 AM
