adjusted tiger's stance - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsSportbikeTrackGearMotorcycle.com
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 05-29-2007, 10:05 PM   #1 (permalink)
Favourite Bike: 2004 Tiger (Black)
I found that my tiger needed to have the preload set at 4-4.5 to have the front end not feel light. I weigh 230 or so with gear. This preload made the bike just a little taller than I wanted; I couldn't quite flat-foot it. So, this weekend I raised the front fork tubes in the triple-clamps around 15mm. This let me reduce the rear preload to 3. The front end feels very well planted and the handling seems a little quicker.
has anyone else done this?
PizzaMan
2004 Triumph Tiger (Black)
pizzaman383 is offline
Old 05-30-2007, 12:49 PM   #2 (permalink)
Hi Pizzaman383, I have dropped my forks through by about 10mm and have the preload set on about 4 on the rear, I weigh about 120kilo and the bike handles much better, the front end does not feel as spongy as it did before and at 6' 3" I can just get both feet down flat footed.
If it's not green, it ain't mean!
Jacko34 is offline
Old 05-31-2007, 06:25 PM   #3 (permalink)
Other Motorcycle: Ducati 749
There's plenty of threads here on lowering the front by up to 24mm. Mine's at 22mm right now and when I can find the time I'll probably change it back to 19mm as it seems a bit too ready to drop into corners. OK for a sports 600 but not what I want from this great big green thing.
greenman is offline
Old 05-31-2007, 06:25 PM   #4 (permalink)
greenman is offline
Old 06-01-2007, 05:08 PM   #5 (permalink)
BigStripey's Avatar
Up to the '05 models (which had the steeper rake angle) raising the fork legs really makes the difference. I have tried everything from 10mm up to 22mm.
The best setting i have found is 19mm, it lets the bike turn in really easily but not 'fall in' like it does at 22mm.
Big Stripey
BigStripey is offline
Old 06-02-2007, 12:05 AM   #6 (permalink)
I'm measuring the distance I raised the forks between the top of the triple-clamp to the line where the cap and the fork tube meet. Is that the right way to measure or do you measure from the triple-clamp to the top of the fork nut?
PizzaMan
Old 06-05-2007, 06:02 PM   #7 (permalink)
pizzaman, you are correct - the measurement is usually taken from the top of the yolk to the top of the stanchion
MrChrome is offline
Old 06-06-2007, 06:06 PM   #8 (permalink)
dropped mine by 10mm and what a difference. I wouldn't go as far to say that its sports bike flickable but it is a lot more manoeuvrable and balanced. Seems to dive less as noted above and frankly, I'm well chuffed.
MrChrome is offline
Someone well adjusted to me a favour ? FifeTiger Tiger Chat 3 08-28-2007 04:32 AM
How many here have adjusted their own valves? Triple_Rider Speed Triple Forum 27 01-23-2007 11:45 PM
Tiger's slipping to second place in my heart Jamo Tiger Chat 12 12-19-2006 11:36 AM
MInimum tools to change the Tiger's tire's/tyre's TiggerTwo Tiger Workshop (archive) 5 06-28-2006 01:38 AM
Cornering Techniques/Tiger's Natural Environment FifeTiger Tiger Chat 16 04-18-2006 05:18 AM
