Clutch lever query. - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.comHonda Powersports SportbikeTrackGear
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 05-28-2007, 07:05 PM   #1 (permalink)
Favourite Bike: My 06 Tiger
Outrunner's Avatar
I am a Tiger newbie and I find that the clutch lever is a long reach from the bar compared to the Sprint I had before, mind you it did have span adjusters.
Does anyone have a fix for this? I did find a replacement lever assembly on a website but it said that the Triumph hand guard could not be fitted to it so that's not much good to me.
Every day above ground is a good day!
Outrunner is offline
Old 05-29-2007, 08:18 AM   #2 (permalink)
robbie's Avatar
Hi Ourrunner
this is what I have done
Clicky
works for me and you can still use the stock hand guards
starter lock out also not a problem for me
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
robbie is offline
Old 05-29-2007, 09:37 AM   #3 (permalink)
I leave a bit of excess slack in the cable and try to use light gloves.
The slack allows you to pull in with your finger tips then the leave will slide into your natural pull position.
Seems to avoid to reach that most of us have experienced.
Chris
Arrybash is offline
Old 05-29-2007, 01:45 PM   #4 (permalink)
Outrunner's Avatar
Thanks for the tips guys, I will be off into the shed after tea to see what I can rig up. Not too sure about disabling the starter switch as the bike is still under warranty. :???:
Andy.
Old 05-30-2007, 04:57 AM   #5 (permalink)
Tassie_Tiger's Avatar
What about these adjustable ones from Triumph Online
http://www.triumph-online.co.uk/inde...&productid=848
Roger Harvey
Hobart, Tasmania
Tassie_Tiger is offline
Old 05-30-2007, 12:23 PM   #6 (permalink)
Favourite Bike: '96 Tiger
Mudhen's Avatar
I ground down the fulcrum of the lever to get it to sit closer to the bars...cut the balls off, too, to make them shorter because they still would hit my Acerbis guards.
(my bike is a Steamer, though, not sure if fuelies have the same lever setup)
Pat
'96 Tiger
Mudhen is offline
Old 06-08-2007, 03:57 PM   #7 (permalink)
oldndumb's Avatar
:wow: :wow:
[ This message was edited by: oldndumb on 2007-06-08 13:59 ]
Oldndumb
Caveat lector
oldndumb is online now
clutch lever for an '01 955iLimited Speed Triple Forum 1 06-12-2007 09:58 PM
Clutch Lever TIGER1454 Tiger Mods & Bolt-Ons (archive) 4 04-08-2006 08:33 AM
clutch lever ditchrat69 Club Cafe' 1 03-03-2006 08:55 AM
Clutch lever stinebiz Twins Talk 0 11-14-2005 08:19 PM
sprag clutch query Daytona Deliberations 6 06-08-2004 12:51 PM
