I need a shorter side and centre stand - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGear
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 04-28-2007, 04:23 PM   #1 (permalink)
I've had to have my '04 tiger lowered cos I'm vertically challenged. This has meant the centre stand is totally redundant unless there are 2 of you to pull it up. The side stand is ok but it doesn't feel safe leaving the bike so far upright.
Does anyone know of any company that produce shorter side and centre stands or can you tell me how to shorten them......bearing in mind I don't have any welding equipment.
Bikermouse
Bikers are the best people,so stay safe, keep the faith......and ride
Bikermouse is offline
Old 04-28-2007, 10:46 PM   #2 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Take em off--one at a time and take em to a welder and have them shortened. You need to figure out how much to tell him to shorten them. I lowered my 1050 Tiger and I plan to shorten the side-stand; however, I am going to leave the center stand alone. Once you learn to put a Bonneville on the center stand, the Tiger is a piece of cake--even with it lowered. :-D
Larry
Larry
RedBird is offline
Old 04-30-2007, 10:18 AM   #3 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
I put steel sleeves in my stands after cutting them to make sure they were strong enough. I shortened them by about 30mm which is the mean of the amount I lowered the front & back (yes I know the side stand should be different but I've forgotten all my trigonometry, anyway it works).
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 05-01-2007, 12:05 AM   #4 (permalink)
Favourite Bike: Black 2002 Tiger
Other Motorcycle: '06 XR650L
I cut my side stand 1", and like Ian put in a steel sleeve. As Redbird did I left the centre stand alone. It is not much more difficult to lift the bike on to the centre stand even after it has been lowered, though compared to my old beemer it's like lifting an elephant. That said, I've decided to return to the standard height even if it means tippy-toeing around a bit. Riding across the island this weekend two-up (110 extra pounds on the pillion) and with the preload and the rebound turned 'way up I was dragging the centre stand on bumpy corners and rubbing the tire against the bottom of the fender when surfing road waves. Mind you, the sports bike guys were having to slow right down for the same bits of road and all the cruisers do is hold up traffic.
rainycoastguy is offline
shorter side stand (kick stand) ? TriumphTT_2 Triumph SuperSports 6 06-07-2007 07:04 PM
Centre Stand RogerJ Twins Technical Talk 10 07-26-2006 07:20 PM
shorter side stand bretzg Tiger Mods & Bolt-Ons (archive) 1 12-20-2005 11:18 AM
Centre stand Hinckley Classic Triples 11 05-05-2005 10:56 AM
centre stand tango Tiger Chat 0 03-24-2004 09:13 AM
