Right.....got some pics to explain it a bit better....
This is the view from the front of the bike showing the two fixing bolts behind the screen. Also note that i have changed the stick aerial for the flat pod aerial behind the fairing.
This then is the view from inside the fairing, showing the RAM ball mount
This is a view of the RAM extension arm fitted to the ball joint
This is the other ball joint fitted to the back of the streetpilot III itself
Finally, this is the view i get from my riding position, note all the warning lights are clearly visible, and the unit itself is as far out of the wind / weather as it is possible to get.
Hope this explains it better than my words ??
[ This message was edited by: BigStripey on 2007-04-04 11:34 ]
