Chain oilers, what's best for the (06) Tiger? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismSportbikeTrackGearMotorcycle.comHonda Powersports
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 04-03-2007, 08:01 PM   #1 (permalink)
oldrider's Avatar
Sorry I don't know how to search the forum other than going back for hours and hours looking at old posts.
What I want to know about is the pro's and con's about the chain oilers that are out there on the market and how they fit the Tigers?
We have a new 2006 Tiger and I would like to fit a chain oiler to it and think there must be more than one brand out there these days.
I hope this post has as much success as my request for information on pillion peg extensions.
So far this is one of the best forums I have been on for sharing of bike specific information. Cheers John.
Blue 2007 Tiger 955i . (referred to as the 06 model) British specification.
oldrider is offline
Old 04-03-2007, 08:36 PM   #2 (permalink)
Favourite Bike: Tiger 1050 '08
Other Motorcycle: Tiger 955i '06
I am getting Lubetronics unit soon (waiting for delivery now)
I was choosing between scottoiler and this one and decided for Lubetronics as the instalation will not void my warranty.
slayer is offline
Old 04-03-2007, 10:04 PM   #3 (permalink)
oldrider's Avatar
Hi slayer, where did you order the unit from?
Have you got a Webb site I can look at?
Everytime I try a Webb search for Lubetronics I just get a lot of rubbish and cant seem to get away from the same pages.
I don't know if you can get this brand in NZ so would have to buy off shore. Thanks, John.
oldrider is offline
Old 04-03-2007, 10:57 PM   #4 (permalink)
oldrider's Avatar
Further to above request for information, have any of you installed a "Pro-oiler" chain lubricator system to your Tiger?
I found a Webb site for this model and it looks like a good one to me.
They show pics of fitting it to a Tiger 955i too!
Any comments or experiences with this one? Cheers John.
oldrider is offline
Old 04-04-2007, 03:48 AM   #5 (permalink)
Favourite Bike: Triumph Tiger 955i
zadok_oz's Avatar
Here 'tis John: Oiler
'03 Tiger 955i
My Pics: http://www.triumphrat.net/memberalbu...0/ppuser/14275
Ulysses Club # 42613
Marty F
zadok_oz is offline
Old 04-04-2007, 02:36 PM   #6 (permalink)
Favourite Bike: Tiger 05
Silverstripes's Avatar
Hi
I use a scottoiler.
It fitted under the seat and have found it to be very effective.
Fitting is easy with the supplied "T" piece and after that its a question of routing the feed pipe under the swinging arm.
Works a treat
Silverstripes is offline
Old 05-01-2007, 07:25 PM   #7 (permalink)
Lordy
Auldrider,
I can 2nd Silverstripes comments. I have a 12/04 Tiger and fitted a Scottoiler to it. Took maybe 90mins to do properly, mounted it under the seat as did SS and couldn't be happier. The only downside is that it is a tad grotty on the rear rim, but that is much preferable to all the gluggy poo that collects around the front sprocket when using spray on chain lube.
I may be wrong, and will stand corrected if i am, but i am thinking that Auto Transmission Fluid will be a suitable replacement for the "special" lube that is recommended. After all, ATF is a consistant viscosity oil that will withstand extreme pressures in transaxles.
Lordy
Old 05-01-2007, 07:31 PM   #8 (permalink)
Lordy
Auldrider,
I can 2nd Silverstripes comments. I have a 12/04 Tiger and fitted a Scottoiler to it. Took maybe 90mins to do properly, mounted it under the seat as did SS and couldn't be happier. The only downside is that it is a tad grotty on the rear rim, but that is much preferable to all the gluggy poo that collects around the front sprocket when using dspray on chain lube.
I may be wrong, and will stand corrected if i am, but i am thinking that Auto transmission oil will be a suitable replacement for the "special" lube that is recommended. After all, ATF is a consistant viscosity oil that will withstand extreme pressures in transaxles.
Lordy
Old 05-01-2007, 09:35 PM   #9 (permalink)
Favourite Bike: '06 Tiger
JasonS's Avatar
Other Motorcycle: '03 Sprint ST
I have a Pro-Oiler installed on my ST. I've run 14k miles with it installed. It works well, but when touring it is the ideal setup. It applies oil based on wheel rotation. It has a control pad that allows you to increase and decrease the flow on the fly for rain or dirt conditions. You can also give it a manual blast through the control pad. There is a large and small resevoir available. I'd recommend installing your own hall-sensor instead of tapping into the wiring harnes to get the rotation signal.
JasonS is offline
Old 05-02-2007, 03:07 AM   #10 (permalink)
JRO
Favourite Bike: 06 Tiger
JRO's Avatar
Other Motorcycle: 07 FJR 1300
Extra Motorcycle: 07 R3 Tourer
I don't like auto-oilers. They're messy, and sometimes problematic. Just get yourself a good chain lube, and let it go at that.
JRO is offline
Chain oilers? T3 Sport / Touring Forum 9 02-27-2006 01:14 PM
chain oilers kj4nt Twins Talk 3 07-05-2005 05:12 PM
Chain Oilers JasonS Sprint Forum 19 04-05-2005 06:07 PM
Chain oilers? THenryH Maintenance & Workshop Talk 66 03-30-2005 10:56 AM
Chain Oilers thfwsf Sprint Forum 5 07-15-2004 07:38 AM
