Tiger 855i Hagon Fork Springs 2" Shorter Than Standard? - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 07-11-2011, 04:50 PM   #1 (permalink)
Newbie
Main Motorcycle: Triumph Tiger/Cagiva GC
Other Motorcycle: Cagiva Gran Canyon
Have just removed front forks on my 99 855i to fit Hagon progressive springs. A couple of questions 1) the Hagon's seem to be about 2" shorter than those fitted - is this normal? (yes I've checked the box and they are the right ones...) and 2) what weight oil i.e. 15 or 10 - I'm 270 lb so I guess the heavier weight would be a good bet?
Next step, fit the Hagon monoshock - but not until I've got the front end sorted first.
Thanks
Dave
Biggerdave is offline
Old 07-11-2011, 06:43 PM   #2 (permalink)
Legend
Main Motorcycle: '07 Bonneville
Haggis's Avatar
Other Motorcycle: Sprint RS
If the hagons are built to suit you I would presume that the weight of oil the manual recommends would be the one to use.
Did you get some metal (or plastic) pipe with your kit?
Cut the total length of new springs and pipe to match the springs and spacers (if any) you are taking out.
Haggis is offline
Old 07-12-2011, 04:23 PM   #3 (permalink)
Newbie
Hi Haggis,
Thanks for the response - I actually spoke to Hagon today (nice guys) and they seem a bit confused themselves as to why they's changed the spec of the item themsleves in 2010! Previously their stock item was the same length as the OEM spring but the new item (and current stock listing) is definitely 45mm shorter. No, I didn't get any tubes with the kit, so I've just popped down to my local metal stockist and grabbed some off-cut pipe of the same OD to make longer spacers if that's the cure (as seems likely). I'll post how I get on and cheers again. Dave
Old 07-13-2011, 12:53 AM   #4 (permalink)
Legend
Haggis's Avatar
I'm sure some engineer somewhere has a reason.
When I put in progressive fork springs in my bonnie they were shorter than the OEM, but the spacers (fancy word for pipe cut to suit) made up the difference. The bike runs tons better now than with stock.
Haggis is offline
hagon road shocks & progressive fork springs V`s just hagon 2810 adjustable shocks typhoo Twins Technical Talk 11 05-01-2011 04:11 PM
Hagon Fork Springs on TBS ?? NeilD Hinckley Classic Triples 0 02-02-2010 07:52 AM
Hagon fork springs Richybow Twins Talk 7 01-31-2010 10:33 AM
HAGON 2" Shorter Shock CATUCK Tiger Chat 3 07-24-2007 04:58 PM
Hagon fork springs bonnieboy Twins Technical Talk 2 03-25-2007 09:48 PM
