Originally Posted by Strada
Presume you also think there's a good chance it will end up on its' side now and again?
A couple of tumbles will soon ruin that bike! A small dirt bike may end up being cheaper in the long run
Bah! I had a DRZ and while good for the dirt, it sucked on the slab. I would rather try to fit Tiger forks and a new rear shock to the Speedy. Some custom mounts for Jesse bags, an engine guard, and skidplate and I'm good to go.
Stock Speed3 forks are 120mm travel, Tiger is 150mm. The rear shocks on the Speed3 and the Tiger are rated for 150mm. I need to get the length measurements for the Tiger forks vs Speed3. If the geometry changes to much I will need to fabricate a solution to get the rear end higher.
09 White Speed Triple, Racetech Gold Valves front and back set up for dirt/gravel/touring on rough roads, SW Motech dirt/street pegs and Alu-rack, Sunline YZ85 shifter, Rox 2" risers, Scorpion Trail tires.
I don't need no dang "adventure" bike.
