Thanks for the replys. I wanted to follow-up for all interested.
Following up on my original post with pics & notes. I was having lower back, as well as arm & wrist cramp from handle bar position. I added a Corbin seat to help with the back from preventing the forward sliding I got from the stock seat, however it wasn't enough. I looked and called around about risers and my concerns with the ABS & not wanting to deal with new lines or relocating. After about 4+ phone calls I got to Gen-Mar, Now I might get corrected but I believe the set they recommend is either their 1" or a new not WEB listed 7/8" height increase. Because of the fork rack and position of the triple tree you get a 7/8"+ or - of an inch rise and close to a -7/16" or so pull back. You do get a more upright riding position but I got that with the Corbin as well.
Bolt length was very good, had question about the amount of space between the clamps after tightening but reviewed some sites & threads and this is normal for proper tightenting of the clamps.
They offer Black or Aluminum which the color doesn't match all that well to the stock aluminum parts but it is OK!
http://www.zianet.com/genmar/
I would recommend these to anyone with the same issues I had and they are quick to install 5 minutes or less with slight adjustment of the cables and brake lines in how they were fed up through the fork tree.
