From your question, I assume you have a Tiger 1050. I believe Remus has included the feature you are wanting--they didn't originally and probably still don't on their "full race" system, but some on that other forum say the Remus they bought has the mounting provision for the center-stand stop bracket.
In early '07, there were very few--I only found one--that had the provision for the center-stand stop bracket...the Thunderbike silencer. I believe most manufacturers have included this feature in the last year. Don't be surprised if you loose HP with many of the after-market silencers. Many do not design a silencer for the Tiger1050--they just use an existing LOUD can and weld it to an inlet pipe. One person on that other forum had a dyno run before and after installing the Remus Power Cone and he lost about 5Hp if my memory is correct. Most Remus purchasers purchase the Remus for the Tiger 1050 because thay like the looks of the Remus, IMHO.
Larry
