Took delivery of this yesterday. First impressions, it looks well made, nicely finished, with good fitting instructions.
First off, you need to fix the brackets to the screen. Its all pre drilled, and the screws and nylock nuts are provided. Youll need to use a 2.5mm Allen key and a 5.5mm socket or spanner.
Next you need to attatch it to your own screen, you can do this with the double sided sticky pads provided, and in addition you can drill four 3mm holes and secure with the stregthening plates and screws and nylocks. I used a dremmel for this, which was ideal, but any light drill would do.
Just got to get it out for a ride and have a fiddle, ill keep you all informed
