Horn upgrade for Tiger 1050? - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 07-14-2009, 06:27 PM   #1 (permalink)
Newbie
Other Motorcycle: Triumph Tiger 1050
Extra Motorcycle: MV Agusta F4 Senna 750
I'm the proud new owner of a Tiger 1050. I love the bike but I do think the stock horn is a bit wheezy. I want something that will get someone's attention when needed. I looked at a PIAA 115db snailshell blaster, but not sure it will fit where the factory noisemaker goes without getting in the way of the forks or front fender under compression. Anyone else tried this? Thanks.
Fugio is offline
Old 07-15-2009, 06:03 PM   #2 (permalink)
Favourite Bike: 955i Tiger/Speed Triple
Other Motorcycle: Speed Triple/Tiger
There's a few threads on this. Not least mine! Seems the Stebulis Nautilus (130dB+) is the way to go. I believe the standard horn is supposed to be 115dB. Bear in mind the dB scale is a log scale so an increase in a couple of dB can be a doubling of sound pressure.
Tone in't Fens is offline
Old 07-15-2009, 06:15 PM   #3 (permalink)
Newbie
Horn upgrades
Thanks Tone. I had checked back to the beginning of the year and didn't see anything horn related. As soon as I hit send, I got links to several older threads on the horn which I have read. I'm sure there is a way to search all threads by topic or keyword that I haven't discovered yet, but I'll press on. Thanks again.
Fugio is offline
Old 07-15-2009, 08:14 PM   #4 (permalink)
Favourite Bike: Bette 99 Tiger
+1 on the Nautilus, not over keen on the tone but it certainly does the buis
PeteH is offline
Old 07-17-2009, 07:15 PM   #5 (permalink)
No need to be personal.
http://www.triumphrat.net/tiger-mods...-fit-955i.html
Old 07-17-2009, 08:47 PM   #6 (permalink)
I was`nt, tone as in noise against Tone as in you, it did cross my mind when I posted it though
PeteH is offline
Old 07-18-2009, 03:37 PM   #7 (permalink)
Favourite Bike: 1970 Triumph T100S Tiger
Don't forget to check out www.tiger1050.com the forum there is dedicated 100% to your bike, with lots of tech info.
Matthew in TO is offline
Old 09-20-2010, 10:31 PM   #8 (permalink)
Favourite Bike: Tiger 1050
concours's Avatar
Other Motorcycle: 1974 Norton Commando 850
Extra Motorcycle: 1973 Yamaha TX750
I added the Fiamm Highway blasters, both high and low note. Fabbed an offest aluminum bracket and tucked them up under, pointing forward. Works the balls! (a treat!)
Too much is just barely enough...
concours is offline
Old 09-26-2010, 05:10 PM   #9 (permalink)
Favourite Bike: Triumph Tiger 955i
Hi, I posted a bit about a cheap but really good horn which will fit both Tiger 1050 and 955i a few weeks ago, The Landrover Defender low tone horn fits brilliantly and sounds really good. you can pick them up from most LR 4X4 stockists, for around a fiver. (Part No YEB10027)
Mark T is offline
Forced upgrade to 1050 :((( slayer Tiger Chat 9 01-30-2010 04:29 AM
Air Horn on 1050 radio_dog Tiger Mods & Bolt-Ons (archive) 12 04-29-2007 05:24 PM
upgrade horn for Bonnie jerseyjeff Twins Technical Talk 15 04-14-2007 10:32 AM
Horn upgrade (yes, I did the search first) white06S3 Speed Triple Forum 9 08-20-2006 10:45 PM
Horn UPGRADE tigertales Tiger Mods & Bolt-Ons (archive) 1 07-25-2006 05:31 PM
