Originally Posted by giantbutcherdog
does fitting a k&n air filter make much difference and do you have to have the engine remapped and how easy or hard is it to fit i know the tanks got to come off
Blimey is there an older question!!,does the bike make more HP,no,does it respond better yes it does,if your going to fit one,dremmel the blanking plate out of the air box,that will give the engine an major boost,worried about doing that?? buy a secondhand airbox of e-bay like i did,think i paid £12!!
Have alway run mine since the day i bought it new with off road map,was concerned about the airbox mod and K+N,runs perfect including one major high speed run in Italy on the stop for the best part of a 100 miles!.
Fitting is easy,just make sure the tank is empty before you attempt to lift it off the bike,because that can be interesting,even if it's half full,and to make the most of job,fit a 19t engine sprocketcause the engine will pull it like a stock 18,although were you live hardly important!!.
