lowering link for '99 Tiger 885i - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 05-18-2009, 04:36 PM   #1 (permalink)
Favourite Bike: 1999 Tiger 885i
Extra Motorcycle: 1979 Honda CB750F
Hey guys,
I've searched around here and can't find any info on where to locate a rear lowering link for a 1999 Tiger 885i. The dealer has one for somewhere on the north side of $150. There's gotta be a cheaper on than that, right? Please let me know if you know of any. Thanks.
Aaron
aaronjorr is offline
Old 05-19-2009, 04:08 PM   #2 (permalink)
Put on a Happy face.
Originally Posted by aaronjorr View Post
Hey guys,
Aaron
A lowering link??
winger is offline
Old 05-19-2009, 05:43 PM   #3 (permalink)
the rear shock is directly mounted to a pivot on the swingarm.... there isn't a "doggie bone" type link that would work... Shorter shock maybe.
cantilever is offline
Old 05-19-2009, 07:01 PM   #4 (permalink)
I found one online last year, but for the life of me I can't remember where. It wasn't a dog-bone shape one. It was odd(ly shaped) … but what on these 885's isn't?
Old 05-20-2009, 05:21 PM   #5 (permalink)
Favourite Bike: 2003 Tiger 955i
Other Motorcycle: '99 Striple 955i
Extra Motorcycle: '72 BSA B25FS,'53 AJS 18S
My understanding is as Cantilever's: the shock mounts directly onto the swinging-arm, there's no linkage involved at all, so no scope for lowering that way. You *might* try turning the chain tension eccentric through 180 degrees. That will lower the back about 40mm. You'll have to space the chainguard mount out though. It works for me.
ChazzyB is offline
Old 05-22-2009, 04:24 AM   #6 (permalink)
Smile
If there was a dog bone(which there isn't) you would'nt have the hassle of the chain tension that you do with the Tiger,depending on 1 up or two up,but you've only got to look at the bottom of the shock were it bolts direct to the swing arm to realise that!!,i was just hopeing to let you down a little easier than Cantilever
winger is offline
Old 05-22-2009, 09:50 AM   #7 (permalink)
Thanks guys. I appreciate the info. Winger, are you saying the chain tension is supposed to be adjusted based on number or riders? Is that a matter of shifting the back wheel fore and aft? That sounds a little irritating.
Old 05-22-2009, 11:43 AM   #8 (permalink)
Set the chain tension as you see fit,sit on it,either lean down and feel the chain tension,or get a helping hand to check,then get a pillion on and check again,if you set the chain as per the book,with 2 people on it will be like a banjo string.
winger is offline
Old 05-22-2009, 08:31 PM   #9 (permalink)
Winger, I don't play the banjo. But I did live in Arkansas during college. Anyway … thanks for the info.
Aaron
1050 Tiger Lowering Link? DirectorLJ Tiger Mods & Bolt-Ons (archive) 13 03-08-2009 05:53 PM
Lowering Link havemycake Speed Triple Forum 3 02-28-2007 07:43 PM
SP4 Lowering link SP4invista Triumph SuperSports 6 05-23-2006 05:23 PM
need pic of lowering link kaholo603 Triumph SuperSports 3 02-28-2006 12:46 PM
