Shifter could be shorter/Brake could extend farther - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 05-01-2009, 12:01 AM   #1 (permalink)
Does anyone feel like the shifter could be shorter? I would also like my brake to extend out more so that I don't have to point my toe in to brake.
Has anyone addressed this issue and if so I would love to see pics.
Thanks
2005 Tiger
pallos100 is offline
Old 05-04-2009, 06:13 PM   #2 (permalink)
Favourite Bike: Maggie, my 1999 Tiger
TucsonBill's Avatar
Other Motorcycle: Jack, my 2001 Tiger
Extra Motorcycle: Shaza, my 2000 Trophy
Aluminum shifters wear out if they're allowed to get loose. Mine was not able to be tightened when I got it. I found a Honda shifter in a wrecking yard that I took home, sawed off, and rewelded to the perfect length for me. It's steel so it will last longer and can be tightened tighter than the aluminum original. As for the rear brake, it works just fine for me.
William Fee
Iron Butt #26777
Tucson, Arizona
TucsonBill is offline
Old 05-14-2009, 10:52 AM   #3 (permalink)
blacktiger's Avatar
I extended my brake lever by bolting a piece of 3mmx20mm alloy bar onto the top. The lever is just long enough on top to drill two 4.5mm holes and to get the M4 nyloc nuts into the groove on the underside. Countersink the holes in the alloy extension piece, round off the outer end and you're good to go. Obviously, you can make it as long as you like.
As for the gear lever. Some levers from MX bikes fit quite well but you'll have to hunt for the length you want. We all have different size feet.
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
blacktiger is offline
How to extend a spring? ColinHitchcock Maintenance & Workshop Talk 6 11-29-2006 07:34 PM
Gp shifter or reverse shifter for t595 or 955i a82383 Daytona Deliberations 6 05-09-2006 01:24 PM
Rear brake pedal & shifter lever rvbeemer Twins Talk 7 11-26-2005 08:44 PM
swapping brake and shifter YD Maintenance & Workshop Talk 0 09-03-2005 02:24 PM
side mirrors...extend? Stroke Tiger Chat 8 07-12-2005 01:35 PM
