fog light switch - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Tiger Mods & Bolt-Ons (archive) What's on your Tiger? (Threads in this sub-forum will be progressively moved to their relevant model sub-forum)
Old 04-30-2009, 03:29 PM   #1 (permalink)
DAGAD's Avatar
fog light switch
Hi Guys. Just got some projection fogs for the Tiger. The kit comes complete with relay, etc. but I need a switch to operate them. I would like a splash proof rocker to fit next to the heated grip rocker on the facia panel. I can get the heated grip switch for £20 but wondered what you guys have used and where you have mounted them?
Next question is, is there a favourite conection place to get the high amp power to feed the relay?
Thanks, Roy.
DAGAD is offline
Old 04-30-2009, 07:03 PM   #2 (permalink)
Favourite Bike: 2005 Triumph Tiger 955i
The Kurgan's Avatar
Thanks, Roy.
I bought a lighted toggle switch from Circuit City for $5. Works like a charm. My fog lights are hardwired directly to the battery (with an inline fuse). See photo of location of switch:
2005 Triumph Tiger 955i British Racing Green
Photos of my Tiger: CLICK HERE
Have a listen: CLICK HERE
R.A.T.# 1081696
The Kurgan is offline
Old 04-30-2009, 07:44 PM   #3 (permalink)
Favourite Bike: My 06 Tiger
Outrunner's Avatar
I have one of the round switches sold by the people in the link below.
http://www.thetoolboxshop.com/0-531-...tch-1096-p.asp
Mine is fitted in the dash next to the heated grip switch, it does not need to be a high Amp rating as all it is doing is energising the relay, the power to my switch is taken from the sidelight wiring and the relay is wired through a fuse direct from the battery.
Andy.
Every day above ground is a good day!
Outrunner is offline
Old 05-01-2009, 03:13 AM   #4 (permalink)
DAGAD's Avatar
Thanks guys. I am going to vehicle wiring products this afternoon, I like the look of their splashproof toggle switch and at less than £3 inc. vat, it's not going to break the bank!
I am trying to avoid wiring the high amp side direct to the battery and I am also looking for a connection point for the high amp for my Stebel Nautaless horn. One place would be the supply side of the starter solanoid? Need to take a look at the wiring diag. and see if anything lends it's self readilly.
Roy.
DAGAD is offline
Old 05-02-2009, 07:55 PM   #5 (permalink)
Favourite Bike: Bette 99 Tiger
Took mine straight off the battery with an in-line fuse fitted, saves mucking about
PeteH is offline
Neutral light switch gregp Hinckley Classic Triples 5 06-05-2010 03:22 PM
main light switch greenocktriple Twins Technical Talk 9 12-16-2007 11:05 AM
Light ON/OFF Switch Ronnierockster Twins Talk 55 09-13-2007 09:44 PM
light switch on 02-04 lillebror Speed Triple Forum 2 07-13-2006 10:10 AM
brake light switch? Tumbleweed Classic, Vintage & Veteran 3 05-01-2004 09:04 AM
