Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 07-17-2008   #1 (permalink)
Favorite Bike: '07 Tiger
Whisperinsmith's Avatar
Other Motorcycle: '06 Sprint, sold along with '05 America and '69 Bonnie
Extra Motorcycle: 200cc cheap dirt bike
1050's oil issue. Triumph comes through
My 2007 Tiger has an oil consumption problem. A big one. Triumph and the techs at my dealer came through and found the problem and have the solution. It was the valve seals. A kit is in the mail and I should have the bike back early next week. Total warranty. It's nice to see both the dealer and Triumph working together to solve the problem.
Some of you have mentioned an oil issue with your 1050 engines. The valve seals are a good place to start troubleshooting. (Some Sprints as well.)
Life. Fill 'er up. It's all we got.
http://www.armchaircommando.org/benn...Bash/Home.html
Bennington, VT May 31, June 01 2008
Whisperinsmith is offline   Reply With Quote
Old 07-17-2008   #2 (permalink)
Did you have other symptoms? Shouldn't bad valve seals eventually foul plugs?
'07 SY Tiger
05' Y Thruxton...sold
05' B Thruxton...sold
I hope to open/acquire a Triumph dealership in a few years...
Hozer is offline   Reply With Quote
Old 07-17-2008   #3 (permalink)
Good news, John. "back in the saddle again"
playinthestreet is offline   Reply With Quote
Old 07-17-2008   #4 (permalink)
johnparjr's Avatar
How much oil was yours using I use about 250cc per 1,000 miles and I am told it's within specs
johnparjr is offline   Reply With Quote
Old 07-18-2008   #5 (permalink)
Hozer, you've put another concern in my mind now. My plugs were absolutely clean. I'll let you know once I get the bike back how it all turn out. The only visible symptom (other than low oil and overheating) was on the exhaust. Black/brown oil smear around the exhaust pipe.
Johnparjr, I was using anywhere from 1/2 quart per 500 miles to 1 1/2 quarts. I found it depended on speed. Faster rpm's, the more oil was pushed through.
And Playinthestreet, I can't wait to get "back in the saddle again"! I should have it back early next week.
Old 07-20-2008   #6 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
I sure hope that fixes your oil burning problem--keep a close check on it. Burning that much oil, I would bet on broken rings...I don't know how they have managed to break rings on assembly of new engines, but it appears (from reading the tiger1050.com forum) that has been the case on a few Tigers.
Larry
Old 07-21-2008   #7 (permalink)
Favorite Bike: 02 D955i
drakewn's Avatar
Sounds like it's just the exhaust valve seal.
drakewn is offline   Reply With Quote
Old 07-22-2008   #8 (permalink)
Moderator
Favorite Bike: Blue 08 Tiger -Current
ruscook's Avatar
Other Motorcycle: White07 SpdTrple -crashed
Extra Motorcycle: Red 06 Sprint -Sold
Whisper, that's great news about the warranty work. Good luck with the fix.
Russ
ruscook is offline   Reply With Quote
Old 07-22-2008   #9 (permalink)
chrisell's Avatar
Wow. Triumph actually honoured a warranty claim? You must be in a unique club of 1.
We should have a collection or something and present you with a medal.
C.
http://www.carbibles.com
chrisell is offline   Reply With Quote
Old 07-23-2008   #10 (permalink)
Moderator
ruscook's Avatar
I've had 3 triumphs, 2 of which have required warranty work. I've had no problems with Triumph honoring the warranty. Biggest issue, a bit slow on the approval for one issue, but then all was very well looked after. This was the Sprint rear drag link failure and I was one of the first in the world with this problem, 3 1/2 months before the worldwide recall.
The second problem was a leaky battery on my 2 day old Speed Triple. All affected shock, exhaust compoents were replaced with no quibbling, and the rear swingarm cleaned and repainted.
So all in all, I'm not happy Triumph seem willing to accept a couple of % points more warranty work than other manufacturers but give them credit for honoring the warranty when needed.
Russ
Triumph mag issue 03 out now! Cardiffian RAT - United Kingdom 13 04-07-2008 04:17 AM
Triumph mag issue 03 out now! Cardiffian Biker Hang-Out 13 03-11-2008 01:22 PM
Cam chain on 1050's casperghst42 Sprint Forum 32 03-03-2008 08:50 AM
Triumph Mag Issue 2 jameskiwi Biker Hang-Out 14 12-25-2007 04:45 PM
RUNNING IN & which OIL for 1050's neil1052 Modifications & Workshop Talk 4 06-18-2005 10:51 AM
