2005 Temperamental Idle When Hot - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 03-15-2005, 12:32 AM   #1 (permalink)
Slim_Dave
Has anyone noticed problems with idling on a hot engine? It only seems to happen when the engine has been ...
<UL>
<LI>run for a while
<LI>shutdown fairly briefly
<LI>restarted (obviously)[/list]... but she definetely seems to be unhappy about running at idle.
Any thoughts?
Old 03-15-2005, 10:07 PM   #2 (permalink)
Diego's Avatar
When you shut the engine down, are you doing it with the ignition key only?
John
Old 03-15-2005, 11:06 PM   #3 (permalink)
Slim_Dave
Oh yes -- I saw a post about this before, so I'm pretty religious about it.
Old 03-17-2005, 07:34 PM   #4 (permalink)
I had the same problem with my 03. The dealer hooked it up to the game boy and determined that the computer had lost it's programming! Apparently the bike was running on some kind of default setting. He loaded the latest tune and it has been fine ever since.
Take it to the dealer, whatever it is it'll be covered under warranty.
03tiger is offline   Reply With Quote
Old 03-17-2005, 07:34 PM   #5 (permalink)
Old 03-17-2005, 07:57 PM   #6 (permalink)
PLease keep me informed of any new developements, especiall if they solve your problem as it sound very much like what I'm facing with my 02.
Edward J Gardner
Midlothian TX
Hayduke is offline   Reply With Quote
Old 03-17-2005, 07:57 PM   #7 (permalink)
Edward J Gardner
Midlothian TX
Old 03-18-2005, 12:14 PM   #8 (permalink)
Slim_Dave
Okey dokey, shall do. I'm dropping by the dealership later to pick something up and I'll see if they've got time to check up on it a bit quick. Thanks buddies.
Old 03-19-2005, 02:55 PM   #9 (permalink)
The idling problem occurs to 05 Tigers with the new EFI system.
Apparently the early ones left Hinckley with the fuel pressure set too low. When I got my BRG 05, I came directly from the 04 and was puzzled by what seemed to be a tamer and rougher engine. The idling problem also made itself annoyingly apparent. A quick phone to the utterly helpful gentlemen at Hinckley Warranty confirmed the problem and after a short while I was notified by my dealer, Classic Motorcycles of Toensberg, Norway, that new software was available. This was quickly installed and all idling problems were cured.
The engine also became smoother and stronger through the rev-range.
It is always nice to have a problem like this solved, but the question that begs to be asked is: How come Triumph didn't diagnose the problem during testing of the new system?
Timian is offline   Reply With Quote
High idle when hot onnel Club Cafe' 7 02-11-2008 03:58 PM
Hot 16 year old Girl in Hot tub......Nice sprintst99 Sprint Forum 2 03-06-2007 08:20 PM
adjusting the idle for hot weather silverfox Twins Technical Talk 10 06-25-2006 07:47 PM
Idle speed when engine is warmed up (HOT) johnquinnell Classic, Vintage & Veteran 6 03-06-2006 04:49 PM
Idle Problems on 2005 T-100 sacco Twins Talk 5 10-10-2005 05:02 PM
