oil warning light
hi folks,
slight problem with the oil warning light, it is not coming on when you switch the ignition on, have taken the front fairing off and checked the bulbs and looked for loose wires to no avail. anyone else had this problem and should i be concerned.
05 tiger ,17000 miles oil level is fine.
cheers
