Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
BikeBandit
Old 04-26-2008   #1 (permalink)
oil warning light
hi folks,
slight problem with the oil warning light, it is not coming on when you switch the ignition on, have taken the front fairing off and checked the bulbs and looked for loose wires to no avail. anyone else had this problem and should i be concerned.
05 tiger ,17000 miles oil level is fine.
cheers
the_beast is offline   Reply With Quote
Old 04-26-2008   #2 (permalink)
Favorite Bike: 1050 S3
Hiya
I had the same problem with my S3. Turned out to be the oil sensor itself.
Try earthing the wire to the sensor with the ignition on - the light should come on then.
In case you're not sure where it is, it kinda looks like a spark plug thingy going into the crankcase behind the middle cylinder.
hth
avion is offline   Reply With Quote
The warning light on the left FifeTiger Tiger Workshop 9 09-24-2007 12:47 PM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 08:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 08:18 AM
ECU warning light TorqueyT Tiger Chat 14 04-17-2005 05:31 PM
