Alternative Oil Filter - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports Motorcycle.comSportbikeTrackGear
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 03-08-2005, 01:31 AM   #1 (permalink)
Does anyone know of a Fram or other oil filter that can be substitued for the Triumph filter for a 97 Tiger? I am getting a little tired of paying $12 plus postage for a filter, rather then $6/7 bucks for one at the local auto parts stores. Thanks!
MG :???:
Old 03-08-2005, 06:37 AM   #2 (permalink)
Most filters are made by only one or two manufcturers, the only difference is the name on the can, ie Triumph.
If you change your oil regularly it is not critical that you use overpriced Triumph branded filters.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 03-08-2005, 11:25 AM   #3 (permalink)
A few that will work are;
Mobil 1 P/N M1-108
Purolator Pure One P/N PL14612
NAPA Gold P/N 1365
WalMart Supertech P/N ST6607
There are many more if you are interested.
These are all car filters that share 20x1.5mm threads, 14psi by pass valve, anti-drain back valve, gasket diameter of appx. 2.3 inches and are about 2.5 inches long.
FRAM makes a bike specific model, PH6017A but I would reccomend against using it. Do a google search on FRAM filters, their quality is more than a little suspect.
I have been using the Mobil 1 M1-108 for the last year and a half. Autozone had a deal on them so I bought a 5 year supply!
Good luck.
03tiger is offline   Reply With Quote
Old 03-08-2005, 10:27 PM   #4 (permalink)
Favourite Bike: S3
I believe the filter mentioned by 03Tiger are spin-on type used on 99 and newer Tigers. Your 97 uses cartridge type filters such as Fram CH6012 and Emgo 10-20300. I know that Purolator and Wix also make these filters, but I don't recall the p/n's. I use the Emgo in my 98. Good hunting.
smartin108 is offline   Reply With Quote
Old 03-08-2005, 11:19 PM   #5 (permalink)
Tigertrax's Avatar
Try a Hi-Flo filter ... might be the H-401 .. about $5.
TigerTrax
Life's A Journey . . . Don't Miss A Turn !
Tigertrax is offline   Reply With Quote
Old 03-09-2005, 12:15 AM   #6 (permalink)
Oops! I guess I should have paid closer attention to the first post. Yes the filters I mentioned are spin on types for the 955 engines. Sorry about the confusion.
Old 03-10-2005, 12:07 PM   #7 (permalink)
Thanks to everyone for their help. And 03 Tiger, no problem. If anyone is ever planning a trip to Alaska let me know and I'll help in anyway I can.
Mike
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-12-2007 12:49 AM
parts sticky? alternative fuel filter 2000 sprint st stwanted Sprint Forum 5 12-10-2006 04:48 AM
02 ST alternative oil filter - in OZ ? harrya13 Sprint Forum 4 09-21-2006 08:13 PM
Alternative Poke the Hole in the Oil Filter ArmyBonnie Twins Talk 3 02-20-2006 08:23 PM
triumph speed triple oil filter alternative? roadkill Speed Triple Forum 7 09-03-2005 11:58 AM
