Espen36, please don't rely on the oil warning light to tell you the oil level. It won't. this is simply a low oil PRESSURE warning light and, with the engine turning, will probably still remain off with half the oil missing!
Better to check regurlay for the first few weeks as suggested. The procedure is layed out in detail in the owners manual and requires you to warm the bike to normal running temperature then, after switching off, let it rest for ten minutes before checking. My 06 is coming up for 10,000 miles nad has never needed topping up.
Jon
