05 Tiger dies at idle - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports SportbikeTrackGearMotorcycle.com
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 02-08-2005, 11:32 PM   #1 (permalink)
Casey
Picked up my neeew orange Tiger two weekends ago. Bike is great but dies at idle on occasion. At 240 miles the dealer has it and is checking with Triumph on the Fuel injection program. Anyone else have this problem?
I've got to say that the dealer is awesome. He's letting me use a Multistrada as a loaner. I'd ridden both bikes and chose between the two. The Duck is nice, but I'm really glad I went with the Tiger.
Old 02-09-2005, 04:48 AM   #2 (permalink)
There is a few things to keep in mind to keep the fuel injection happy.
1. Never give throttle when you start the engine. The computor will handle everything for you.
2. Always turn off engine with the key. Just another thing to keep the computor ECU happy.
3. When you turn on the key at start up, wait a few seconds before you start. The fuel pump build up fuel pressure and the ECU will wake up.
It can happen that engine stall when you let off throttle fast. There are some earlier threads about that.
Tigers shutting down
engine stall
Mine died on me once and as you can se on those other threads you are not alone with this problem.
Good luck!
Anders
doitright is offline   Reply With Quote
Old 02-09-2005, 05:24 PM   #3 (permalink)
I've heard this one both ways. The guys at the shop say use the engine cutoff switch, then turn the key off. I assume this has been hashed out here so I'll look around.
My 01 started stalling at idle and it turned out to be a compression problem. It also became hard to start. I'm sure that's not your issue.
2005 Thruxton
2000 Speed Triple
whoa is offline   Reply With Quote
Old 02-09-2005, 05:24 PM   #4 (permalink)
2005 Thruxton
2000 Speed Triple
Old 02-10-2005, 10:02 AM   #5 (permalink)
djr
The kill switch is for emergency use only and bypasses the normal shutdown mode of the bikes computer. Owners who regularly shut off the bike with the kill switch have frequently had problems.
Compare it to shutting down your pc by just pulling the plug from the wall socket every turn. It is not going to take long for your pc to start playing up. The bikes internal computer is no different.
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
Old 02-10-2005, 10:02 AM   #6 (permalink)
djr
David
My Photo Album
My Tiger pages
Old 02-10-2005, 01:00 PM   #7 (permalink)
I've had the habit of shutting down with the sidestand. I assume that's bad too?
I haven't had any problems yet (that I know of) but I'm wondering if I should get the computer remapped anyway?
Guess I'll tape the red switch for a while to remind me to develop a different habit . . . .
Paul
______________________
"Either we figure out how to keep corporate cash out of the political system, or we lose the democracy."
Molly Ivins, July 2006
paulie is offline   Reply With Quote
Old 02-10-2005, 01:00 PM   #8 (permalink)
Paul
Old 02-10-2005, 04:31 PM   #9 (permalink)
The sidestand switch is also for emergency only.
Note that Triumph should let us all know this information. The manual says what to do, but not what NOT to do.
Rather than tape the switch, imagine your Tiger is a fighter plane and needs a proper and defined starting and shut down procedure.
We can all dream can't we?
Timtiger is offline   Reply With Quote
Old 02-10-2005, 04:31 PM   #10 (permalink)
'97 Thunderbird (triple) Pops, Engine Dies, cannot idle gliderace Hinckley Classic Triples 21 11-10-2008 02:38 PM
Idle set-screw? and Idle rate at start MontrealMike Triumph SuperSports 2 05-01-2006 06:37 PM
EFI tiger won't idle ericp Tiger Workshop (archive) 5 11-13-2005 11:15 PM
2002 Tiger Stalling at Idle Hayduke Tiger Workshop (archive) 30 04-17-2005 06:50 PM
dies on idle, after quick throttle release Speed Triple Forum 15 02-20-2005 10:36 PM
