Check your chain tension
Hi Guevera, I had a similar problem on my ´06 model and fixed it yesterday by giving the chain a bit more slack than the owners manual recommends. the dealer probably set the chain tension as per the manual/triumph (40-45 mm/1.5"-1.75" slack), but if you do a chain tension search on here you´ll find that most tiger chains run too tight under load at that setting, causing the gearbox to whine under load, the recommendations are to slacken it off to 50-60mm/2"-2.375" depending on the use its getting( passenger, luggage, suspension settings, overweight pilot!, etc.) I run mine at 55mm slack measured with the bike on the side stand at the point behind the weld on the swingarm. hope this helps
MadridTiger´07 955i
