Motorcycle.com
Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 01-05-2008   #1 (permalink)
oil filter stuck
hello to everyone. here is my problem. 2 days ago i ve noticed a small oil leak from the oil filter of my 06 tiger. i already had done 1500 miles with this filter and no problem so far. i tightened it with a filter tool too much i think and the leak got worse. trying to loosen it afterwards in order to change it for a new one, it turns but does n't come out. has anyone experienced this problem. what maybe the damage on the inside of the oil plate. what do i have to do to get it out?
Thanks
fif955 is offline   Reply With Quote
Old 01-05-2008   #2 (permalink)
fif955
You have to remove it. I suspect it has sprung a leak at the join where the base of the filter joins the " cup " of the filter. It may be spinning on this join. I would " Butcher " the cup part off the filter, remove the filter part. Then you can get hold of the base of the filter. Using some grip type tool , spin it off.. Good luck.
I guess you dont need to be told these filters can be put on by hand when fitting a new one. As my good wife tells me from time to time " If all else fails try reading the directions"
Kiwi Tiger is online now   Reply With Quote
Old 01-05-2008   #3 (permalink)
thanks kiwi. i'll try and tell you the results. so stupid of me.
your wife is a wise woman.
any idea of why this happened in the first place?
Old 01-05-2008   #4 (permalink)
1 On too tight.
2 Had a knock.
3 Junk filter.
4 Prob several more reasons.
There should be a rubber ring between the filter and the engine. Soooo hopefully there will be no damage.
Ha Ha "your wife is a wise woman" .....I guess after 29 years married she reads me like a book.
Old 01-06-2008   #5 (permalink)
zadok_oz's Avatar
Speaking of filters; I use the K&N filter which has the nut for easier removal.
http://knfilters.com/oilfilter.htm
Ride Safe
'03 Tiger 955i
My Pics: http://www.triumphrat.net/memberalbu...0/ppuser/14275
Marty F
zadok_oz is online now   Reply With Quote
Old 01-06-2008   #6 (permalink)
Favorite Bike: Tiger 995i
I think you have either a faulty filter or caused damage by over tightening it. You should not have to fit it using a tool, hand tight is enough, always remember to oil the seal before fitting.
Remember, you are tightening into an alloy block.
"Those who can make you believe absurdities can make you commit atrocities"
-Voltaire
byjingo is offline   Reply With Quote
stuck oil filter luiz Daytona Deliberations 18 08-22-2007 10:12 PM
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-11-2007 11:49 PM
Removing $#%!!!@#$ Stuck Oil Filter mecscc Twins Technical Talk 17 12-15-2006 09:43 PM
Oil Filter Stuck Tight Galesa Sprint Forum 19 11-04-2005 01:37 PM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 01:00 AM
