Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 01-01-2008   #11 (permalink)
Favorite Bike: Speed Triple
"And rust in my gas tank from the beginning and the dealer says triumph says it is not a problem"
I doubt if Triumph says it is not a problem, unless your dealer is trying to get Triumph to handle it under warrantee.
My S3 used some oil at break in, but hasn't used a drop since.
I would imagine there are a lot of bikes being improperly run in or are being run with oil viscosities not recommended by Triumph, so I wouldn't be put off what your reading in the posts here or elsewhere.
As far as I am concearned the 1050 motor is as good as anything out of Japan I have owned over the years.
Cburt is offline   Reply With Quote
Old 01-01-2008   #12 (permalink)
johnparjr's Avatar
[quote=Cburt;908727]"And rust in my gas tank from the beginning and the dealer says triumph says it is not a problem"
Of course Im trying to get it covered under warranty wouldnt you If a brand new bike had rust.
johnparjr is offline   Reply With Quote
Old 01-02-2008   #13 (permalink)
blacktiger's Avatar
[quote=johnparjr;908975]
Of course, but "it's not a problem" probably means that they think the fuel filter will stop any particles getting into your engine.
H
'02 Tiger955i in black.
Old 01-02-2008   #14 (permalink)
johnparjr's Avatar
[quote=blacktiger;909686]
Dang Black tiger do you work for Triumph that is exactly what they said.
Old 01-03-2008   #15 (permalink)
I would be at the dealer having a major tantrum if I had rust in my tank. It should be taken care of before it gets into the engine.
mattf301 is offline   Reply With Quote
Old 01-03-2008   #16 (permalink)
johnparjr's Avatar
I agree Matt triumph will not cover it so Ill probably end up buying a new tank there about $760
Old 01-05-2008   #17 (permalink)
johnparjr's Avatar
Well just got back from the dealer the Bike used about 260cc of oil in 1700 miles
Is the gearbox on the 1050 Tiger different from the 1050 Sprint? bareyb Tiger Chat 6 03-16-2008 03:14 PM
Has anyone had problems diagnosing tire problems? ohiorider Twins Technical Talk 1 07-18-2007 09:58 AM
1050 Sprint vs. New 1050 Tiger bareyb Tiger Chat 32 05-21-2007 07:34 AM
Possible rear suspension problems - 1050 Pcdabbler RAT - United Kingdom 0 09-01-2006 05:54 AM
Both Tigers winger Tiger Chat 6 06-22-2006 04:06 PM
