+1 for Powerlet as a source for male BMW type (actually John Deere tractor was using this type connector prior to BMW  ) connectors. They also have a good selection of adapters.
"...but, what sort of things fit into it?"
Since this outlet is NOT switched on/off with the key, I would recommend using it for things like battery tenders, air compressors, small trouble light, etc. I would install another plug that is wired from switched wires for heated clothing, etc.
Larry
