Owning both, a Girlie and a Steamer, and having taken both off road, I think I can say: There is no so great difference between the to bikes.
Both have almost the same wheels (Steamer's rear tyre is a bit slimmer than the Girlie's)
The Steamer weights 10 kg more than the Girlie (255 vs 245 ready to run with 90% fuel).
The ground clearance of a 955i is nt so great compared to a Steamer, due to a complete space wasting design of the exhaust system. The 885i is a lot better in this area.
The fork travel of a Steamer is 230mm. The Girlie only has 170mm way o travel.
The steamer is fitted with a bash plate that will hold off a lot of the things the ground has in stock for you. The Girlie's "bash plate" is just for looking nice...
The Girlie's engine is better than the Steamer's.
I think it's just a matter of different flavours. All in all, they are allmost equal in it's offroad abilities.
I chose the Steamer to convert it into a "lightweight" dual sport because it was cheaper to get. And, when beeing abroad in low-developed countries, there are certain advantages: it has the lowest compresson rate of all the Hinckley triples (will use the worst grade fuel) and "every blacksmith" will be able to repair a carburrator. Try this with a fuel injection system...
If you like to see it in action,
click here
Have fun!
Patrick
[ This message was edited by: Patrick on 2007-05-25 01:02 ]
