Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 03-08-2007   #1 (permalink)
Thought I would commute to work on the tiger today as the weather was due to be reasonable.
Its a 37mile blast down the motorway and at 7 in the morning it can be cold at this time of the year.
Yippee for heated handle bar grips.
However after about half an hour, I noticed the throttle was not returning when I released it, it needed to be manually closed. It was alright at lunchtime, but the same thing happened again on the way home with the heated grips on.
A bit of spannering when I got home concluded that the grip was expanding with the heat and contacting the bar end. The rubber on the grip was acting as a friction damper and stopping the throttle from closing.
I have since managed to move the throttle along the bar to give a bit more clearance, but it seemed to be tight to move hence the gap did not increase that much.
I dread to think of the consequences if the throttle got totally jammed whilst doing 80mph down a motorway.
Anybody else experienced this problem?
Chris
Arrybash is offline   Reply With Quote
Old 03-09-2007   #2 (permalink)
Chris,
I had the same problem, only when the heated grips were on. I tried trimming a bit off the end but was worried about cutting the wire. In the end I put a couple of washers behind the bar-end weight to space it out from the grip. Seems to have worked ok.
Steve.
Swoody is offline   Reply With Quote
Old 03-09-2007   #3 (permalink)
marauder2's Avatar
On 2007-03-09 02:50, Swoody wrote:
Chris,
Steve.
thats just what i have done,6 small washers behind the bar end weight solves the problem completly,and i love my new hearted grips,but i had the same problem witth them expanding. :-D
marauder2 is offline   Reply With Quote
Old 03-10-2007   #4 (permalink)
I had exactly the same problem only today. A couple of washers sorted the problem.
Trunkie is offline   Reply With Quote
Old 03-11-2007   #5 (permalink)
blacktiger's Avatar
Try slackening the whole switch cluster and sliding it inwards as far as the cables will allow then just 1 or 2 washers under the bar end should cure the problem. Or, you have a cruise control when the heated grips are turned on.
H
'02 Tiger955i in black.
Old 03-11-2007   #6 (permalink)
So it isn't just me that has had the problem. I thalf suspected when it happened it would prove to be a common problem and therefore a design fault.
I tried slackening the throttle and brake lever to slide the throttle inwards but something must be holding it as I got very little travel.
The washers is obviously the solution. I have plenty in my garage.
Thanks for the tips guys.
Chris
Old 03-12-2007   #7 (permalink)
Favorite Bike: Tigger of course (2004)
bigD's Avatar
If I recall correctly, which I frequently dont these days, but I im fairly sure of this one. there is a little hole in the bar & a corresponding nib on the throttle/Cluch assemblies which is ment to keep everythin put once the two halves of the casing are screwed together.
D
Big D
If you can't be kind, at least have the decency to be vague.
bigD is offline   Reply With Quote
Old 03-14-2007   #8 (permalink)
It was on the cards for the best day of the week today, hence I took the Tiger into work again.
It was also very chilly at 7 this morning and I had to use the heated grips again.
It appears that the limited movement I obtained from slackening everthing was just sufficient to give the clearance to stop the throttle binding.
I didn't have to space out the bar end.
However I do agree with BigD there must be a hole and nib. I did notice there is a wire going into the bars which I assume must be for the heated grips.
The nib would be to stop the throttle body cutting the wire if moved to far.
Chris
Tightening Mirrors PhxMan Sprint Forum 9 07-15-2008 12:17 AM
self tightening chain? entropy Hinckley Classic Triples 7 09-08-2005 08:58 PM
Chain tightening? UJMrider Hinckley Classic Triples 4 08-09-2005 08:13 PM
Tightening Chain Justbergone Daytona Deliberations 2 06-08-2005 06:29 PM
Tightening Mirrors JayR Triumph SuperSports 5 02-18-2005 08:11 PM
