Replacing headlamp bulbs - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 09-06-2004, 11:29 AM   #1 (permalink)
Is it me? Or is the Tiger handbook a little vague...?
I need to replace a headlamp bulb. The book says: "Remove cockpit." Sounds simple... but... the only obvious fasteners are the two in the face panel, that only appear to retain the coloured strip in front of the warning lights.
Can anybody help by advising (in a little more detail than Triumph have) how to "Remove cockpit" ?
Thanks in advance,
'Drew
Old 09-06-2004, 11:52 AM   #2 (permalink)
djr
you need to take off the front fairing to change the bulbs!
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
Old 09-06-2004, 11:57 AM   #3 (permalink)
robbie's Avatar
Hi Drew
you are looking at the wrong side.
stand in front
remove windscreen 4 screws
remove indicator (air vent) panels 3 Allen screws a side
remove front plastic 4 Allen screws 2 under wind screen 1 each side under air vents
remove light cluster 3 Allen screws
pull forward and unplug each light and the side light connector
change bulbs and refit in reverse order
very simple? not!!
have you tryed to replace a bulb in a Toyota
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
robbie is offline   Reply With Quote
Old 09-06-2004, 12:11 PM   #4 (permalink)
from the service manual:
Cockpit Removal
1. Unscrew the four fixings securing the windscreen to the fairing and remove the windscreen.
2. Remove both cockpit trim panels by unscrewing the two fixings.
NOTE - The indicator assembly will come away with the side panel. Take care not to strain the wiring.
3. Unscrew the four fixings holding the cockpit fairing to the cockpit sub-frame, and lift the fairing away from the sub-frame.
FYI: Cockpit to sub-frame torque = 5 Nm
Trim panels = 3 Nm
Windscrren = 3 Nm
Headlight/Position Bulb Replacement
1. Remove seats
2. Disconnect the negative battery lead
3. Remove the cockpit
4. Release the screws securing the headlight unit to the support bracket and release the unit (There should be a fixing on each side and one in the center)
5. <u>Headlight bulb only</u> - disconnect the multi-pin electrical connector from the headlight bulb to be replaced and remove the rubber cover.
6. Detach the wire bulb retainer from the clip (it is not necessary to undo the screw) then remove the bulb from the light unit.
7. <u>Position light bulb only</u> - without pulling on the wires, ease the bulb holder from the retaining socket in the rear of the light unit.
Good Luck!
Old 09-06-2004, 01:28 PM   #5 (permalink)
robbie's Avatar
Cockpit Removal
That is strange I have two screws on the out side and one on the inside attaching it to the tank?
mine is an 03 i do know of someone who said that they didn't have screws there so it may be a year thing
so please check before you pull to hard
TIGER 955i 2003
Old 09-06-2004, 02:19 PM   #6 (permalink)
Many thanks to all for your comments :-) I would never have sussed that lot out. Damned glad I had the full compliment of headlight relays fitted... imagine going through that palava on the road-side, in the wet... or snow!
Cheers,
'Drew
Old 09-10-2004, 01:34 PM   #7 (permalink)
Cheers,
'Drew
Very good point safety point for running with two headlights
The 1st annual pigmy tiger meet was somewhat quiet.
knarf is offline   Reply With Quote
Old 09-10-2004, 07:45 PM   #8 (permalink)
Soooooo are the Phillips
Vision Plus the best bulb to go with when replacing the stockers?
Gearloose is offline   Reply With Quote
Old 09-10-2004, 08:15 PM   #9 (permalink)
BigStripey's Avatar
Without incurring the national debt by purchasing true xenon generators and bulbs, then i believe the 'Vision Plus' to be the best of the rest. They really are as bright as they say....
Big Stripey
BigStripey is offline   Reply With Quote
Replacing ST Headlight Bulbs TXRyder Sprint Forum 10 05-11-2006 10:43 PM
Replacing Headlamp Mounting Bracket Mercury Hinckley Classic Triples 13 11-19-2005 03:23 PM
Headlamp bulbs for my Trident Les T3 Sport / Touring Forum 12 10-23-2005 12:37 AM
More powerful headlamp bulbs 55/100w Les Maintenance & Workshop Talk 3 05-30-2005 05:35 AM
