I've just suffered from this, tank was nearly empty after the 24k service, went to fill up and got the sucking sound and whoosh of air, thought nothing of it.
Half way through a tankful and noticed last night the left ahnd fron 'pod' of te tank was bent inwards, quickly opened the filler cap and 'WHOOSH', in goes the air.
Lots of mumbling about bl00dy monkeys can't even re-fit a tank properly, called the dealer to book it back in to have the tank re-set.
Then thought, it can only be a hose, surely even I the Mechanical Muppet can spot a trapped hose ? Popped off the left hand panel to the rear of the tank and there's two hoses, followed one of them down and sure enough, it's kinked. Straighten it out, there's some 'sighing' as a little more venting takes place and a reassuring smell of petrol vapour.
Wrapped some tape around the kinked section of tube, just to help stengthen it as it was showing a tendency to kink back at the slightest opportunity.
One thing I did notice - these breather tubes are very long, reaching all teh way down to the gearbox housing, do they have to be so long ? It's the length, and having to wrap it all up behind the engine, that's causing the kinking.
