06 Transmission - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 09-29-2006, 10:55 AM   #1 (permalink)
T100Tom
Back in August I picked up a used 06 Tiger. It now has about 1700 miles on it. I've been using it mostly for commuting to work and love it. I've moved up from a T100 which I bought new in '03. My question involves the 'smoothness' of the tiger transmission. In comparison to the T100 it is more 'notchy' and, at times, much more difficult to get in to neutral or 3rd. Some of this may be my technique which I've adapted to the tiger and the problem has gotten slightly better. Is this typical? Will it improve with more miles? The T100 was definitely smoother with more positive shifts between gears, up and down. However, I do remember the T100 smoothing out as the miles were put on.
Any thoughts?
Old 09-29-2006, 11:02 AM   #2 (permalink)
All Triumph gear changes improve with mileage.Maybe 10,000 miles.My Tbird has 34,000 miles and has a better gear change than my 05 Tiger.Also it changes more smoothly at higher revs,which maybe you're not using compared to a T100 ?
JohnRimmer is offline   Reply With Quote
Old 09-29-2006, 11:53 AM   #3 (permalink)
Favourite Bike: 2011 Speed Triple
I'll second that... my engine at 18,000 miles is better than ever (gearbox too)... Chain tesion has a lot to do with gearbox too... Took a good 12,000 miles to fully loosen up...
Russ
Sofalofa is offline   Reply With Quote
Old 09-29-2006, 12:37 PM   #4 (permalink)
I noticed a big increase in smoothness, after the 6000 mile service. This was the point that the oil was changed from semi, to fully synthetic.
I also agree that an over tight chain will always make a gearbox seem notchy.
I checked my chain tension, with the bike on its wheels, with someone sitting astride the bike. This simulates the actual tension when going along the road. The real chain slack, when measured after this is always at least 60mm. Hope this helps.
CATUCK is offline   Reply With Quote
Old 09-29-2006, 12:52 PM   #5 (permalink)
JRO
Favourite Bike: 06 Tiger
JRO's Avatar
Other Motorcycle: 07 FJR 1300
Extra Motorcycle: 07 R3 Tourer
At 11,000miles, my '06 has been improving for some time. It's still not quite there, though. I particularly don't like the shift between 1st and 2nd - too clunky. The other gears give me no problems. I've also had my cable adjuster turned to max, pretty much since I got it.
JRO is offline   Reply With Quote
Old 09-30-2006, 01:01 AM   #6 (permalink)
My experience has been pretty much like that of others.
Originally my 06 was very notchy and has gotten much slicker and better.
What was more disconcerting is that early on it would actually bind on upshifts, usually 1-2 or 2-3. That has vastly improved and has gone from a random thing that would happen several times on a ride, to a very rare thing that may not happen at all on a given ride.
Run it, the bike is going to get better and better.
Joe S.
twinrider is offline   Reply With Quote
Old 09-30-2006, 01:39 AM   #7 (permalink)
Tassie_Tiger's Avatar
My '05 now has 29,000kms, and the gearbox improved greatly over the first 20,000km.
You will find that if you 'preload' the gear shift before disengaging the clutch that the changes will be much smoother and slicker (an old BMW R1150RT trick. Their gearboxes belong on tractors!).
Also fully synthetic oil helps, but don't go thinner than 10W.
Roger Harvey
Hobart, Tasmania
Tassie_Tiger is offline   Reply With Quote
Old 10-02-2006, 12:25 PM   #8 (permalink)
T100Tom
Thanks for the response. I'm hoping it smooths out as the miles accrue.
Old 10-02-2006, 03:25 PM   #9 (permalink)
Favourite Bike: 01 Tiger
Other Motorcycle: 02 Sprint RS
Extra Motorcycle: another 01 Tiger
I agree with everyone else, but also check that the freeplay in the clutch is right. I have 68,000 on my 01 955 Tiger and it really got alot better at the 12,000 mile oil change/checkup
nortoncharlie is offline   Reply With Quote
Old 08-04-2007, 10:19 AM   #10 (permalink)
papydawg's Avatar
i waited for an '06 Tiger to get the "improved" clutch among other features. the shifting is still very notchy at about 3,000 miles - much more than my two 955 Sprints had from mile one. engine vibration, even after loosening the chain, is significantly more than the Sprints as well.
i hope usage and oil change will improve it.
pd
papydawg is offline   Reply With Quote
8 Speed Transmission? TheBoatDude Biker Hang-Out 7 09-01-2007 04:16 AM
transmission ratios? Chinookmark Speed Triple Forum 2 07-28-2006 02:16 PM
out of my transmission 77bonniehotrod Classic, Vintage & Veteran 1 06-25-2006 05:16 AM
transmission/clutch again CaptainMorgan Speed Triple Forum 19 06-22-2006 06:21 AM
transmission rebuild help Maintenance & Workshop Talk 0 04-30-2005 09:14 PM
