I've had my Lowrance iWay 500C for about a year now and really like it.
Pros: Big touch screen, waterproof (been in several downpours), a 10G hard drive dedicated to MP3, and on-line updates. You can even play around with the code if you want. It comes with a RAM mounting kit that will work on the bars. Lots of custom configurations for the screen which is very easy to view in direct sunlight, and you can also set the screen for nighttime driving. Another major positive, at least to me, is that it has a power supply monitor (voltage reading) that you can have displayed on the screen. I've always liked having more information than idiot lights...it allows me to make sure the alternator is working fine when running, and battery is +12V> when the bike is off. I have the unit tied into my Autocom so the seductive voice makes sure I make all the right turns, and then, the music continues where it left off.
Cons: A little pricey, but shop around. When I first got mine, the kit came with the external antenna and the base mount for the car. Neither of these come with the standard kit now...I don't think. Beyond that, you do need a dedicated +12V power feed (no batteries) and it may or may not have map support for our friends on the other side of the pond. I know Lowrance offers European maps on SD, but I'm not sure about the on line map updates for the iWay. The only other thing is that you have to plan your trips on the GPS itself as there isn't stand alone software for your PC... where you can download the trips/waypoints. This really isn't a big ordeal as the screen is fairly large and the unit comes with an AC adapter and a USB cable. The USB cable also makes it easy to download music and updates.
Overall, I have been very happy with the iWay500C so far. This is my first Lowrance GPS as I have always been a Garmin/Magellan user. I have had Lowrance electronics for the boat and found them to be very dependable.
There are lots of GPS's out there that are probably very worthy....not sure how many are waterproof. Sorry for the lengthy dribble.
