Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 03-26-2006   #1 (permalink)
TigerTamer
Ok - I am selling the stock hardcases off my 05 Tiger. I want to go ahead and remove all the mounting hardware. I see the two big bolts under the passenger seat for the luggage rack and the rear plastic, but how do you get the bolts out that are sealed in the luggage rack? Don't you need to remove the luggage rack and the rear plastic so you can remove the rear brackets of the sidecase mounting plate - or am I way off base.
Any help (especially with pics) would be greatly appreciated!
TIA,
Scott
Old 03-27-2006   #2 (permalink)
This is how.
Remove seats.
take out little black plug things on the rack.
Unscrew the long bolts underneath the little black things (8mm socket i think)
Unscrew the large bolts which hold the 'feet' of the rack which are either side of the seatind lock mechanism.
Take off rack, the short struts which hold the rack up and rear fairing off.- if you have an alarm the trigger switch may make it go off, just hold it down with some insulation tape.
Look at how the rails are held on, its quite simple and ingenious. Using an allen key on the top of the bolt and a socket driver for the nut unscrew each one then pull out the short plates which will become obvious.
use a soft rubber mallet or similiar to un hook the rails.
easy
remember to take off the supports on the passenger footpegs as well.
B
boocat is offline   Reply With Quote
remove discs for mounting? dazco Twins Technical Talk 3 10-04-2007 10:04 AM
Sidecase racks for Scrambler cuteandcool Twins Technical Talk 4 07-19-2007 12:02 PM
aftermarket hardware? wyoming_tiger Tiger Chat 4 06-16-2007 01:39 AM
Request for pics of Pannier mounting hardware... wryder Tiger Chat 8 07-20-2006 07:59 AM
WTB GIVI sidecase racks for Sprint ST dkamest110 Sprint Forum 0 11-14-2004 10:57 AM
