Simple Help urgently needed - spark plugs?? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
New BonnevilleOntario TourismSportbikeTrackGear
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 03-09-2006, 03:57 PM   #1 (permalink)
ash999
My dad has a triumph tiger 855 (i believe) its r-reg and carburettor model, well could anyone give me simple, direct instructions to removing and replacing the spark plugs, i.e. does the tank need to come off, and can you gain access if you raise the tank still connected, baring in mind my dads a div when it comes to mechanics. I would help him but never worked on his bike and has got a manual but gets confused as its for several models.So can anyone help me out with direct intstructions Any help greatly apprciated.
Hes left it for a while and its tempermental and wont start on choke, its just catchin and barely managed to start yesterday, its turning over, guess its old spark plugs as its due for a service.
Cheers
Ash
Old 03-10-2006, 04:00 AM   #2 (permalink)
Yes the tank will have to come off.
Once this is out of the way you will have unrestricted access to the top end of the motor where the three spark plugs are located.
Just take off each plug lead/coil and use a long reach plug spanner to remove/replace the plugs.
Be careful not to overtighten any screws/plugs here as it is easy if you are not careful to strip threads.
TF.
Tigerfeet is offline   Reply With Quote
Old 03-15-2006, 05:15 AM   #3 (permalink)
You checked the battery's ok, could be why it's not catching.
A good dose of WD40 round the HT leads and plugs to get rid of any damp might help also.
But a bike that's been standing with the battery conected, I'd always charge it first.
FifeTiger is offline   Reply With Quote
Old 03-15-2006, 05:32 AM   #4 (permalink)
Yep could be the plugs, but it could also be the carb's.
Been left for a while, sitting outside,,,,,,? hmmm, could be the dreaded Triumph carb' rot.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 15 10-27-2009 04:25 PM
Advise Needed For Spark Plugs 5ta custom build head markbungy Classic, Vintage & Veteran 5 03-12-2007 08:32 PM
Advise Needed For Spark Plugs 5ta custom build head markbungy Twins Talk 1 03-12-2007 03:55 PM
HELP NEEDED URGENTLY PLEASE!!! markyellowboots Daytona Deliberations 6 05-30-2006 07:04 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
