Tiger Chat For owners and riders of Hinckley Tigers: 885, 885i, 955i and 1050i
Old 01-08-2006   #1 (permalink)
clive955's Avatar
Have had the odd problem recently with my 02 Tiger. This is really rare as I have not had many problems in the 8000 miles Iv had her. A couple of times Iv filled up with normal unleaded and not super unleaded and never thought much about it until the last time i did it. Every so often when going through traffic the engine would start hunting and then suddenly cut out. The engine would turn over normally but would not fire up until about the fourth go. Has anyone else had this problem with the two fuels and which is recommended by Triumph.
Secondly lots of photos Iv seen on this site have BMW Hand guards (SORRY FOR SWEARING THERE GUYS) but like most of us who do a lot of touring they are better than the Tigers original items. Question is what model BM are they from and do you have to mess around alot to fit them. :hammer:
Green is Mean
clive955 is offline   Reply With Quote
Old 01-08-2006   #2 (permalink)
Might have just been some bad gas as I've always used the regular unleaded or the mid-grade (if at a un-major brand gas station) and never used premium as my dealer and other guys have said that's a waste of money as these are designed to work better with the lower octane ratings. Always thought it was better to use premium but have now figured out my two bikes don't need it and don't benefit from the higher octane.
gary b
bretzg is offline   Reply With Quote
Old 01-09-2006   #3 (permalink)
blacktiger's Avatar
The recommended fuel in the UK is called "Premium Unleaded".
The use of any other grade is harmful to the environment because "Super Unleaded" is designed for use with a catastrophic converter which the '02 doesn't have.
It will,apparently, run on real sh1t octane. The ECU is programmed to cope.
H
'02 Tiger955i in black.
Old 01-09-2006   #4 (permalink)
djr
the tiger is designed (FI ones) to run on 95octane (European octane rating) fuel. Anything more is simply going to be blown out the back. It could be you have a bad batch of fuel or perhaps some ***** has gotten into the tank.
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
Old 01-09-2006   #5 (permalink)
clive955's Avatar
Thanks guys, had the fuel filters out and changed when I serviced her about 1000 miles ago. maybe as you mentioned a bit of s*** fuel so will see if see runs ok on normal unleaded.
Anyone got the answers to the handguards.
Green is Mean
Couple of ST questions L0giX Sprint Forum 3 05-04-2007 05:55 AM
Hello And a couple Questions Vaer Twins Technical Talk 6 11-27-2006 02:37 AM
couple of questions about "00 RS Olyrider Sprint Forum 8 10-09-2006 10:00 PM
Couple of questions.. GenIIIMrDuece Speed Triple Forum 2 10-02-2006 12:54 AM
Help please on a couple S3 questions... kwajazz Speed Triple Forum 5 09-29-2006 02:27 PM
