One solution (this from HAMLIN, a Triumph mechanic over on the Tiger1050 forum), is to fill your bike with oil all the way to the top, tie your clutch lever to the grip (to separate the plates), lean the bike over on the clutch side (against something solid), and let sit over night. Drain in the morning to the proper fill level, and (hopefully) have a non-sticking clutch. In the meantime, when in neutral, try counting to 5 after pulling in the clutch lever before you put it in 1st. If that doesn't help the clunk, you have a sticking clutch.
