Double Shifting and Starting in Second - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
Old 08-09-2012, 09:00 PM   #1 (permalink)
Main Motorcycle: 2010 Tiger 1050
TommyTFC's Avatar
Other Motorcycle: Sea Doo GTX-DI
I'm finding that with my 1050 I often shift up two gears at a time. The engine handles it well and it saves a lot of clutching. Now I've added starting out in second gear. Any of you blokes do that?
(I don't really say "bloke". I'm from Iowa.)
TommyTFC is offline   Reply With Quote
Old 08-12-2012, 07:55 AM   #2 (permalink)
Main Motorcycle: 800 Roady
Cburt's Avatar
No, not really. I'll short shift sometimes when traffic is loafing along.
Non of the blokes I know do it either.
Cburt is offline   Reply With Quote
Old 08-12-2012, 10:13 AM   #3 (permalink)
Main Motorcycle: 2012 Tiger 800XC ABS
Extra Motorcycle: 2 Honda CT 70s
I downshift two at a time sometimes when conditions warrant. But never take off in second on purpose. I also don't skip gears, part of the fun of riding a bike is shifting IMHO. I ride an 800 though.
CSAW is offline   Reply With Quote
Old 08-13-2012, 12:39 AM   #4 (permalink)
Main Motorcycle: Tiger 955i
I go back and forth between skipping a gear and hitting them all. Kind of depends on my mood. I think it shifts better when I hit all gears, but could be my imagination. I read somewhere where a guy didn't use the clutch when shifting (after 1st) to save wear and tear on his clutch. Tried that too. Not sure I'm fond of that technique. Probably costs more to replace some gears than a clutch cable. . . . .
OHjim is offline   Reply With Quote
Old 08-13-2012, 04:15 AM   #5 (permalink)
Main Motorcycle: 2006 Tiger '955
There's two recognised ways to change gear on a bike - "sequential" and "block" changing.
Sequential is the obvious one that we all do. You are always in the correct gear for the speed and load on the bike. It helps with engine braking and saves wear on the brakes.
Block changing is usually only done when changing down. You lose all your speed on the brakes, pull in the clutch and block change down a few gears in one go to the correct gear for your speed. I've never heard of anyone block changing up the box. You would have thought it would put more strain on the engine and internals.
Safe riding.
Regards,
Graeme.
Tiger-G is online now   Reply With Quote
Old 08-13-2012, 09:11 AM   #6 (permalink)
I suppose it could if you are getting on it. For me, when I do it, I am not in any hurry, merrily rolling along as it were. So, I think (hope) I'm not straining anything. It seems to me that if I were to crack the throttle wide open every start, that would be a lot more stress than block changing.
When downshifting, do you use engine speed to slow or braking? I tend to downshift to slow, thinking I'm saving my brakes. But, I wonder if it's better in the long run to use the brakes as they are cheaper to replace. Thoughts?
Old 08-14-2012, 04:34 AM   #7 (permalink)
Good question about shifting down using the clutch only ??
Anyone had to change a clutch in a Tiger, and if so, how many miles did it have on it ??
Safe riding.
Regards,
Graeme.
Old 08-16-2012, 11:57 PM   #8 (permalink)
With 6 gears I don't find downshifting does much for speed reduction. I will admit that I probably lug my engine more than others here - so perhaps my issues stems from not having much RPM to start with.
eigenvector is offline   Reply With Quote
Old 08-24-2012, 05:18 PM   #9 (permalink)
Main Motorcycle: 2012 Tiger 1050 SE
EsEmDee's Avatar
Other Motorcycle: 1993 Volvo 240 Wagon
OHjim: I have always found myself thinking that using the transmission to slow a vehicle down would eventually wear down the clutch components and/or the transmission itself.......I have had this thought in manual transmission cars and now I think about it on my Tiger 1050.........logic tells me that I would rather pay to replace brake pads at (guessing) $75 per wheel every 10K or so than have to pay (wild guess here) $500 for a clutch replacement and who knows how much for actual transmission work/replacement.
Any of you Senior Members/Triumph Experts care to chime in here?
I would love to get some detailed opinions/life experiences on this topic..........if I don't hear anything in this thread - I will start a new thread dedicated solely to this question.
IN A NUTSHELL THE QUESTION IS: Better to slow the bike with downshifting or use the brakes and then shift down however many gears to get to Neutral or 1st?
Thanks - SMD
EsEmDee is offline   Reply With Quote
Old 08-24-2012, 05:45 PM   #10 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
I downshift and use the brakes (front mainly)
Reason:- I'm ALWAYS in the right gear, I may need to accelerate so being in the right gear is important.
Never had a worn out cluch or gears in 36years years of riding, and never been caught out in the wrong gear.
If you match revs when you change down the the stresses on the gearbox/cluch are reduced. And it sounds good too.
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is online now   Reply With Quote
Questions on shifting & intermittent starting problems rad-lefty Sprint Forum 18 08-19-2011 11:50 PM
Double T^^ AKIRA Biker Hang-Out 4 06-19-2011 12:21 AM
Double Take !!!! dagamed Thunderbird Cruiser Chat 4 04-29-2010 06:40 PM
Double can on a TT? 955iryder Triumph SuperSports 2 03-04-2010 11:52 AM
Double clunk when shifting D-3vil Sprint Forum 7 08-18-2009 04:22 PM
