Hi
I have started to us my topcase and noticed a ' wobbly-ness' (excuse my english) from 80Km/h upwards. I have checked the tire pressure (2.5 and 2.9 according to specs)
Any suggestions from you would be appreciated
thanx and greetz from the Netherlands
WW
My Tiger does exactly the same when the top box is on.
My Trophy 1200 did the same also.
I think it is caused by air turbulence between the rider and the top box as it is not apparent when I have a passenger on the back seat.
TF.
I don't notice any problems with stability with the topbox on, except at high speeds. Are you riding through gale-force winds? If not, I would suggest it could be something else. Easiest way to find out, is remove the top box, and see what happens.
Thanks Guys -> no gale force!
Did just that - without the topbox - and noticed - if less then with the topbox - the same "wobbliness". I checked the pressure again and no problem there (2.5 and 2.9).
Any suggestions ; e.g. a tire allignment (sorry my english is a bit rusty! :clown: )
