Just changed my head bearings at 28600 miles. A fairly easy job on the 955i.
For information for those likely to do the job themselves at sometime. The bearings are :-
TOP, 6205DDUNR This is a ball race with a snap ring around the O.D. & 2xgrease seals.
BOTTOM, 32006JRRS This is a taper roller with a seal moulded onto the inner race that will seal into the headstock bore.
These bearings were availabe from a bearing specialist at prices 30% lower than Triumph wanted.....if they had them!
Take note before the thread is lost.
