Tiger 1050 Headlights - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger Chat For owners and riders of Hinckley Tigers: 800, 800XC, 885i, 900, 955i, 1050i, 1200
post #1 of 11 (permalink) Old 03-03-2011, 04:50 PM Thread Starter
Main Motorcycle: Kwak ZZR1400
Question Tiger 1050 Headlights
One of the first things id like to do to my new Tiger is convert the single running headlight to twin running lights, Anyone know the correct way to do this ?.... Is this an easy mod?
thanks in advance.
teedee is offline
post #2 of 11 (permalink) Old 03-03-2011, 09:13 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
One kit is/used to be called the twin-light driver. It has the necessary parts, wiring, and instructions for doing what you want to do. I did it on my '07--worst waste of time of any mod I have ever done.
If you want some help (from a lighting stand-point) for the dipped beam, this mod helps none, IMHO. One has to run the high beam at about 75% or less output when on dipped beam and/or adjust the high beam down and away from opposing traffic, and this hurts your light output when using high beam.
Both lights shine when high beam is selected--this is the stock setup. About the only thing accomplished from running both lights when dipped beam is selected is how the bike "looks".
If one is seriously wanting to increase the light output of the dipped beam, the best solution, IMHO, is to install HID after one has adjusted the dipped and high beams for proper light. I had to adjust both lights on my '07 and '08 a considerable amount to get them shining where they are supposed to shine.
Good luck,
Larry
RedBird is offline
post #3 of 11 (permalink) Old 03-04-2011, 01:11 PM Thread Starter
Good luck,
Thanks for your opinion Redbird.The reason i want to do it is part cosmetic but mainly because the headlight just doesnt seem as bright as my previous bike (Kawasaki Z1000).
teedee is offline
post #4 of 11 (permalink) Old 03-04-2011, 09:24 PM
The Twinlight Driver I installed was the original one--made by a company (Ecliptec) in Australia. Looks like they have gone through two upgrades since I bought mine. The one they are selling now is called the Twinlight Driver3. I thought there was some place in the USA that was selling them; however, I could not find any. There is one place in the UK (Triumph Online) that sells them, I believe. I ordered the one I installed from Ecliptec in Australia--no problems. Here is a link to their web site.
http://www.ecliptech.com.au/index.ph...=84&Itemid=166
Good luck,
Larry
RedBird is offline
post #5 of 11 (permalink) Old 03-05-2011, 01:43 AM Thread Starter
Good luck,
Cheers my friend, Thats been saved to my favourites for future reference.
teedee is offline
post #6 of 11 (permalink) Old 03-13-2011, 01:48 PM
I would go with the HID upgrade as well.
Best change I made on my Tiger
Tiger 1050 in Gold (bye bye old girl)
Sprint St in Graphite (hello baby)
My Gallery
Beau is offline
post #7 of 11 (permalink) Old 03-18-2011, 02:49 PM
Main Motorcycle: Triumph Tiger 1050
Other Motorcycle: Honda Harley BMW R1050R
I have been told that changing the bulbs in the Tiger 1050 could create excess heat and thus damage the plexiglass that cover the head lights. I hav had a lot of problems with my Tiger: 1. in trying to raise the headlights to an adequate level and 2. seeing at night. Not very bright lights. Any suggestions?
gvillada is offline
post #8 of 11 (permalink) Old 03-18-2011, 10:02 PM
I had to adjust both my '07 and '08 headlights a LOT when I got them. I did; however, have enough adjustment to get them where they should be. The dipped beam has a sharp cutoff at the top, so I adjusted it at the top of the trunk level for an auto in front of me about 8 car-lengths. Yes, increasing the bulb wattage of these headlights is asking for trouble; however, using HID should not cause this type of problem because the running wattage is less.
Auxiliary running lights is a good option also--I run Motolights on both bikes; however, there are some very good options available that cost much less.
Many on this side of the pond on that other forum have used HID's from DDM Tuning in California...cheap, but most have indicated they are pleased with the product.
Larry
RedBird is offline
post #9 of 11 (permalink) Old 03-19-2011, 04:18 AM
Main Motorcycle: Grey 2010 K1300R - currnt
ruscook's Avatar
Other Motorcycle: Blue08 Tiger1050 - trade
Extra Motorcycle: White07 SpdTple - crashed
The twinlight driver will work, and a lot of folks are happy with them. When I had the Tiger (and now on the K1300) I went the HID route for the low beam. Even the 35W HID is 50% brighter. works a treat and reasonably easy to install.
ruscook is offline
post #10 of 11 (permalink) Old 03-19-2011, 10:30 AM
Thank you Redbird and Ruscook. I have installed PIAA's new HID lights on the forks. I have had a problem with them. PIAA is still tweaking them, problems with the transformers, and as under warrantee, I am going to be on my third set in less that 12 months. They have changed the internal transformer again and hopefully this time they will work properly. Ruscook that is one heck of a Tiger page you've crated. Congratulations!
gvillada is offline
06 Sprint 1050 headlights not working Alex06sprint Sprint Forum 11 07-24-2012 01:35 PM
New Tiger - dead headlights Truth4achange Tiger Workshop (archive) 4 06-23-2009 02:08 PM
New Tiger - headlights??? eagle Tiger Mods & Bolt-Ons (archive) 6 04-08-2008 09:34 AM
Sprint 1050 headlights (long) TheArchitect Sprint Forum 7 03-15-2007 02:33 AM
Headlights Did Not Shut Off ! '06 Tiger Tigertrax Tiger Workshop (archive) 6 09-04-2006 12:37 PM
